I am having the same problem on a new Mac Pro 2019. I tried getting rid of the studio one preferences minus user.license and extensions and that worked for about five minutes and then I had the same problem. I tried two different keyboards besides my Apple Magic Keyboard (same problem) and yes my menu does work but only after I select undo like 10-16 times (it is random). I have reported it and send in my system report and I will report back if anything works.
This seemed to happen to me after the latest presonus update. I am using the latest version of Catalina too. |
I read the forums for 4.5 and someone claimed izotope was a problem for them and control z. I don't own any izotope but I decided to try to narrow things down and one plugin seems to cause this problem for me: Get Good Drums Smash and Grab compressor. I just bought it and started using it on a bus. When I disabled it, everything works fine. Super weird. So try to disable some of your plugins and narrow it down and see if one of the plugins is causing the control z problems. It worked for me so hopefully it will work for you.
tombrignall wroteI read the forums for 4.5 and someone claimed izotope was a problem for them and control z. I don't own any izotope but I decided to try to narrow things down and one plugin seems to cause this problem for me: Get Good Drums Smash and Grab compressor. I just bought it and started using it on a bus. When I disabled it, everything works fine. Super weird. So try to disable some of your plugins and narrow it down and see if one of the plugins is causing the control z problems. It worked for me so hopefully it will work for you. Glad you found it! There are a few plugins that do this because of Studio One's very inclusive approach to the Undo History. I think the best bet to fixing this is to contact the plugin manufacturers because I'm pretty sure they don't have to do it this way. When I noticed that VirtualCZ did this I contacted Plugin Boutique and they fixed it in a later version. |
inlikeig wroteAny fix on this yet? I'm new to Studio One. I was seeing if I like it better than logic or pro tools and I do, but I can't work without Undo. Mine works on fresh projects but if I start recording or changing anything it stops. Not a good first impression. I will have to cancel my subscription soon. Full steps to repro from a new project? Have you fully read the thread, it's often related to third party plugins. And please put your specs in the signature below.
Hi everybody, for me it seems that Presonus has tried to make things more complex like for example:
- I delate 1 arranger part (f.e. chorus) and going back with "undo" it's not that simple like 1 click "ctrl+z" and I'm back. I have to click "ctrl+z" as many times , as many was there tracks or other elemnts in this chorus. May be there's function how to choose which part I want to "undo/redo", but i dont know how ... - anybody? For now it's like pain in the a@@ - instead of working I sit and click 20 times "ctrl+z". PRESONUS please give us INFO, or FIX IT, thanks ! Adam |
I open the history panel and go back as far as I need to, one click.
I've don't remember having problems with undo. I have on occasion had plugins that catch keystrokes and don't let them get to S1. If I click off the plugin(change focus) then the shortcut will work again.
I posted this in another thread:
I had this problem too in Version 5.3.065413. (5.4 doesn't show up as available for me. I am on the new Mac M1 mini. Big Sur 11.4 I fixed this problem of the command z not working and having to go in to the history to undo by opening Preferences/Advanced/Console/ and unchecking Enable Undo. GO figure! As an added note I quit Studio One and reopened and rechecked the box and it's still working fine. Bill |
I have been having this problem constantly recently. It seems that an Izotope plugin is spitting out all kinds of parameter changes, just by moving the playhead. The only one i undo is in the history list, which is not fun. I accidently move one thing and blam, no ctrl z, and then its total shitfix
Users browsing this forum: No registered users and 28 guests
