I assumed that the link button in Dual Pan would actually link the left pan with the right pan, so that they moved in unison. Not at all it converts the left pan button into Pan and the Right Pan button into Width, yes you got it Binaural Pan.
The obvious question is why bother having a separate Binaural Pan?
People who can't dance always blame the band.
https://soundcloud.com/gerry-cooper-855281238
Studio One 5 Pro. Windows 10 64 Bit 4 GB Intel 2 Quad Q 9950 @ 2.83 GHz . Focusrite Scarlett 2i4, NI Komplete Kontrol S61, NI Komplete 12 Ultimate, Izotope Ozone 5 and 8. Yamaha HS 80 Monitors.
by Jemusic on Fri Jul 10, 2020 7:24 am
Do some listening tests. When using Dual Pan (no link) setup L and R positions eg 10 and 2 o'clock. Switch into Link mode. Notice nothing changes audibly. Width setting changes (to create the 10-2 o.clock width) and pan goes to centre as it should. You only have to move the Pan control to move this narrow image to the left or right. If you wanted to achieve that without link you would need to automate both L and R.
Binaural Pan is not the same either. Its width goes way out to 200% and the audible effect is quite different. Its designed to either create a mono signal and be able to pan that, or a very wide stereo image and pan control becomes a balance for L and R.
Dual Pan is good for bringing in a stereo image closer to the centre and shifting that either to the left or right.
They certainly overlap though. They can both create mono and pan mono.
Specs i5-2500K 3.5 Ghz-8 Gb RAM-Win 7 64 bit - ATI Radeon HD6900 Series - RME HDSP9632 - Midex 8 Midi interface - Faderport 2/8 - Atom Pad- iMac 2.5Ghz Core i5 - High Sierra 10.13.6 - Focusrite Clarett 2 Pre & Scarlett 18i20. Studio One V5 (Mac), Notion 6.7, Ableton Live 10 Suite, LaunchPad Pro
by Quietly on Fri Jul 10, 2020 7:55 am
Jemusic wroteDo some listening tests. When using Dual Pan (no link) setup L and R positions eg 10 and 2 o'clock. Switch into Link mode. Notice nothing changes audibly. Width setting changes (to create the 10-2 o.clock width) and pan goes to centre as it should. You only have to move the Pan control to move this narrow image to the left or right. If you wanted to achieve that without link you would need to automate both L and R.
Many thanks for that wonderful explanation, sadly its more than probable that my old ears will not pick up such subtleties. :D :shock: :cry:
Users browsing this forum: johnboyd4, kozmyk, leosutherland, robertgray3, Tacman7 and 17 guests
