I cannot connect X-Touch to Studio One in Xctl/MC mode. I have configured the X-Touch as a Mackie control device and it is connected via USB. Studio One sees the connection ports, MIDIIN2 (X-Touch) and MIDIOUT2 (X-Touch), but the X-Touch displays "MIDI: no link."
There is currently a message on Reddit from someone with a Faderport 8 having exactly the same issue. https://www.reddit.com/r/StudioOne/comm ... t_working/ The Xctl/MC mode allows connecting the control surface to both a mixer (XR18) via Ethernet and a DAW via USB/MIDI and switch between them with a single button. This works with other DAWs that support Mackie Control MIDI over USB protocols with the exact same setup I'm using. Any ideas? |
I just found this with no replies....Hopefully you got an answer before this. At any rate look here:
viewtopic.php?f=151&t=41377&p=243536&hilit=XR18#p243536
Studio One 5.1 Professional on Home built i9 10900K on ASUS Z490 Prime-A with 32 GB RAM 64-bit Windows 10 Pro Premium 500GB M2 WD Black SSD (OS) 1TB M2 WD Black SSD Data Drive. Behringer U-Phoria UMC204HD, and/or XR-18 USB 2.0 Interface. Single FaderPort , Behringer X-Touch control. Ozone 10 Advanced, Various Waves Plug-ins including Nx with Head Tracker and Ocean Way Nashville and Abbey Road studios.M-Audio Oxygen Pro Mini 32-Mini-Key Keyboard Controller, You Rock Guitar [Gen 2] Guitar MIDI Controller. Alesis DM10 MKII Studio Kit Electronic Drum Set.
Users browsing this forum: No registered users and 49 guests
