I had to reinstall Windows 10 recently plus all of my software, including Studio One, and all of my plugins. I installed SynthMaster 2.9 but it doesn't show up in S1's Instruments list. Interestingly, it does show up in Reaper on the PC, and also in Studio One and Logic on my MacBook. I've also got SynthMaster One and that shows up everywhere.
I tried resetting S1's blacklist and restarting, but SM2.9 still didn't appear, so I did a rescan to no effect. S1's log file doesn't show anything relevant. I've emailed KV331 Audio Support and all they've suggested so far is what I've already done.
So now I'm wondering if anyone here has had and solved this problem, or if anyone can suggest anything else I can try.
Garry Knight
Studio One 3 Professional
Melodyne Editor 4, NI Komplete 11
Focusrite Scarlett 2i4 audio interface
Windows 10 Professional 64-bit, 16 GB RAM, Core i5
Microsoft Surface Pro 3, Core i7, 8GB RAM, 128 GB SSD
Nektar Impact LX49+, Samson Graphite 25, and Korg microKey 25 MIDI controllers
Novation ZeRO SL MkII mixing control surface
Korg nanoKontrol 2 mixing control surface
Reaper, Logic Pro X, GarageBand
https://soundcloud.com/garryknight
by robertgray3 on Thu Feb 13, 2020 8:34 am
Simple question but have you checked to see if you accidentally hid it or it became hidden in S1? I was just trying to reinstall Trackspacer when I realized I hid it on accident.
Mac OS X Mojave 10.14.6
Mac Pro (Late 2013)
3 GHz 8-Core Intel Xeon E5
32 GB 1066 MHz DDR3
Dual AMD FirePro D500 3072 MB
Quantum 2
by garryknight on Thu Feb 13, 2020 9:05 am
Thanks for the suggestion, but it was a fresh installation of Studio One on a fresh installation of Windows 10. It's not hidden, it's not there at all. The VST is in the C:\Program Files\Vstplugins and Studio One has found all of the other plugins except for SM2.9. What's more, the standalone .exe version of SM2.9 works fine.
Garry Knight
by scottyo7 on Thu Feb 13, 2020 10:13 am
Do you remember if it was an easy installation before?
I just created a new Admin Acct and a few things went astray.
I had to re-find and move some of the sound files for two of my Air Music Technology Instruments to work correctly again.
And iZotope Ozone was on my master but actually wasn't working because it needed to be re-authorized... apparently it saw the new Admin account as a new PC. :roll:
If you've haven't already... Please add your Signature & Gear Info to your Profile Create yours here .
-ASUS i7 Laptop; 16GB; 2 Samsung SSD's; NVIDIA 670MX; Win 10 Home x64.
-S1 Pro 4.6.1; EZD2 2.1.8. Behringer UMC404HD USB A/I.
Synths: Camel Audio Alchemy, Air Tech Music Suite, UVI Digital Synsations.
-Melodyne Studio 4.2.4. Ozone 5, Scuffham S-Gear 2.95, Eleven Rack (all 64bit).
-Akai MPK249. 6 guitars, two Line 6 POD's & an E-bow.
-Fluid Audio FX8 monitors; Dual 28" Displays. Rode NT1; SM58. Faderport;
-My Band: "2GUYZINABASEMENT"
-Just Me
by garryknight on Thu Feb 13, 2020 10:35 am
It was plain sailing the first time. Everything installed and worked OK.
UPDATE: I've just found out that iZotope VocalSynth and StutterEdit are missing, despite the fact that their DLLs are in my Vstplugins folder, and I authorised both using the iZotope Product Portal. And Studio One thinks that Softtube Saturation Knob is installed, but that doesn't show up in the list either! An I'm not sure if that's a VST or an S1 plugin, but it doesn't have a VST in my VSTPlugins folder. Things are getting weirder!
Garry Knight
by sirmonkey on Thu Feb 13, 2020 10:53 am
robertgray3 wroteSimple question but have you checked to see if you accidentally hid it or it became hidden in S1? I was just trying to reinstall Trackspacer when I realized I hid it on accident.
How do you check if something is hidden in S1? And how do you unhide it?
For me, my plugins by Melda Productions scan, and show up in the browser.
But they won't load onto a track. Also, opening a song that has existing Melda
plugs makes S1 hang indefinitely, or the plugs show as "Not Installed".
Maybe a different problem entirely. But if not, maybe there's a solution.
Atari 5200, 64K RAM S1PRO Radio Shack Cassette Recorder w/internal Mic,
by darrenporter1 on Thu Feb 13, 2020 11:01 am
View -> Plugin Manager
Shows all plugins S1 recognizes and allows you to filter the view by manufacturer, plugin type (VST2. VST3, Native, etc) and whether or not they are hidden.
For your Melda issue, I would try un-installing and re-installing to see if that fixes it.
Last edited by darrenporter1 on Thu Feb 13, 2020 11:06 am, edited 1 time in total.
Studio One Professional 4.6.1
UAD-2 PCIe DUO (two of them), v9.11
by leosutherland on Thu Feb 13, 2020 11:04 am
Just a thought, I had similar problem with Diva on my two systems. On one I had a song with Diava inserted on a track as "Diva". When I transferred song to other system, I was getting the same problem - on the first system the device was named "Diva" in the browser, on the second one it was called "Diva(64)", so did not match what was in the song. The fix was to insert Diva into the track again, replacing the "Diva" instance with the "Diva(64)" instance - then everything worked fine.
Strangely, when I then transferred the song back to the first system, it continued to work fine :roll:
Just FWIW. Does that help at all?
...said Halo
Studio One Pro v4.6.1
Serum, Diva, Synthmaster, Massive, Syntronik Bully, MTron Pro, Kontakt/Reaktor Players+stuff, Xpand!2+AIEP3, PPG Wave 3.V, KLC
Reference 4, Reverberate Core
3XS SQ170 Music Studio PC (Main DAW)
Windows 10 x64 (1909)
i7 8700 Hexcore 3.2GHz, 16GB DDR4-2666, 500GB Samsung 970 EVO M.2 NVMe SSD + 1TB SATA HD
Scarlett 2i4 (G2), Korg Taktile 25, Faderport 2018, ATOM
MSI GE62VR 7RF Apache Pro (Standby DAW)
Intel Core i7 7700HQ 2.8GHz, 16GB, 500GB Samsung 970 EVO M.2 NVMe SSD + Samsung 1TB 860 SATA III SSD
by garryknight on Thu Feb 13, 2020 11:54 am
On the Mac, SynthMaster shows up with the name SynthMaster2 for the VST and SynthMaster 2.9 Instrument for the AU version. In Windows, it just shows up as SynthMaster 2.9 Instrument x64 in Reaper, but I think it used to be SynthMaster 2.9 in Studio One. So if I ever get SM2.9 to actually be usable in S1 on Windows, I might face the same naming problem.
But I don't think it has anything to do with my problem, thanks, Leo.
Garry Knight
by jih64 on Fri Feb 14, 2020 4:10 pm
Just shows up as SynthMaster2 in Studio One
Jeff
Studio One 4 Professional (Always Latest) - Windows 10 Pro 64bit 1803
by garryknight on Fri Feb 14, 2020 4:26 pm
Someone on the KVR Audio forums made a suggestion that worked. It was something to do with the folders. I recall that when I first installed it, shortly after reinstalling Windows, I put it into C:\Program Files\Vstplugins. Since then, every time I've tried reinstalling it, the installation dialog suggested that it should go into C:\Program Files\Vstplugins. This time, I uninstalled it and reinstalled into C:\Program Files\Vstplugins\KV331 Audio. And this time, it finally showed up in Studio One! Of course, this doesn't explain why it didn't show up before, even though it showed up in Reaper. But I'm happy to have it back.
Garry Knight
by Jemusic on Fri Feb 14, 2020 5:08 pm
Many DLL's are inside the VST folder but also there are plenty of folders in there too with the DLL's inside them. If Studio One is set to scan the VST Plugins folder then it goes into all the folders inside that for sure.
I have always had my KV331 synths inside their folder inside the VST plugins folder and never had an issue yet.
A good code of practice is to let plugin installs go where the manufacturers want them and leave that pretty well alone. Sometimes they want to put things inside the Steinberg folder and then I reset that to the VST Plugins folder and have never had an issue.
Synthmaster 2.9 is an amazing synth. Looking forward to 3.0 though!
Specs i5-2500K 3.5 Ghz-8 Gb RAM-Win 7 64 bit - ATI Radeon HD6900 Series - RME HDSP9632 - Midex 8 Midi interface - Faderport 8 and 2018- Atom Pad- iMac 2.5Ghz Core i5 - High Sierra 10.13.6 - Focusrite Clarett 2 Pre & Scarlett 18i20. Studio One V4.6.1 (Mac), Notion 6.5, Ableton Live 10 Suite, LaunchPad Pro
by garryknight on Sun Feb 16, 2020 4:32 pm
Yes, thanks. I don't even remember why I wanted them out of their default folder.
Garry Knight
Users browsing this forum: No registered users and 20 guests
