Manged to get Ableton ReWire instrument to bring in audio from Ableton no worries. But struggling with MIDI. Ableton doesn't see Studio One when they're loaded together and S1 has the Ableton ReWire instrument open.
Maybe there a more powerful program specifically for MIDI app to app than ReWire?
(4.6.1/Mac Catalina).
by Tacman7 on Wed Feb 12, 2020 1:17 pm
I use my 8 port midi interface with a patch cable to run midi between cubase and S1.
Think you can do that with virtual midi ports also.
Melodyne Studio - Nectar Impact LX25+
Where 'IS' Shitcreek? and
by shanabit on Wed Feb 12, 2020 3:20 pm
1. Add an Instrument Track in S1 and select the REWIRE category, then REAPER then select your MIDI PORT input and output as REAPER
2. Set Ableton to sync to external MTC or midi clock if it does that
3. S1 HAS to be the Master for MTC sync
4.. Working fine here with Reaper as Rewire Slave
S1 Pro 4.6.1
OSX High Sierra 10.13.6
2010 MacPro Dual 2.4 Quad, 14 GB Ram
by richarddent on Wed Feb 12, 2020 5:43 pm
So it only works if S1 is master. But I need Ableton to be master. ReWire works for audio with S1 sa slave, and it sends accepts Abletons's Midi clock for tempo sync. It should accept Midi notes no?
Users browsing this forum: robertgray3, Tacman7 and 23 guests
