The presets in PSO Classic Orchestra section seem to mirror the instruments in the Classic orchestra.
I have loaded a selection from each and the both look and sound identical.
It's probably me doing something wrong.....
by scottyo7 on Wed Feb 12, 2020 4:03 pm
I have these 3 soundsets too. 8-)
There are YouTube tutorials on what and how they do their thing.
They may look essentially the same but they have different styles and modes.
I'd also recommend reading the PDF that comes with them. ;)
If you've haven't already... Please add your Signature & Gear Info to your Profile Create yours here .
-ASUS i7 Laptop; 16GB; 2 Samsung SSD's; NVIDIA 670MX; Win 10 Home x64.
-S1 Pro 4.6.1; EZD2 2.1.8. Behringer UMC404HD USB A/I.
Synths: Camel Audio Alchemy, Air Tech Music Suite, UVI Digital Synsations.
-Melodyne Studio 4.2.4. Ozone 5, Scuffham S-Gear 2.95, Eleven Rack (all 64bit).
-Akai MPK249. 6 guitars, two Line 6 POD's & an E-bow.
-Fluid Audio FX8 monitors; Dual 28" Displays. Rode NT1; SM58. Faderport;
-My Band: "2GUYZINABASEMENT"
-Just Me
by paulakerman on Wed Feb 12, 2020 4:26 pm
Thanks for replying.
I have downloaded and read the ten page pdf and watched the videos, but i cannot seem to find the difference between those sets in the image.
I will re watch the videos and re read the pdf, as i have probably missed something, but i cannot see what, as all the articulations and and sounds are identical.
I will investigate.....
by scottyo7 on Thu Feb 13, 2020 11:54 am
It could be you have a valid issue.
I haven't used them for a bit but it might be because some have 'modifiers' while the other 'identical' looking patch doesn't.
The 'modifier' range are keys on the left with red marked above them... holding either one down invokes more sound options.
-Just Me
by paulakerman on Thu Feb 13, 2020 12:38 pm
Good point - ill check, thanks
_______________________Update
Just checked and it gets stranger.
I checked between a selection of preset and classic and the articulations were the same, but the sample/file size was bigger in one of the sets, 3-4 mb.
With the choirs, there was a difference in size and a slight difference in reverb, not a noticeable difference in sound though.
I have raised a ticket as it looks to me as though one set is just a later set than the other, so i'll wait until they get back to see what they say
by paulakerman on Fri Feb 14, 2020 3:40 pm
I usually use the Soundset folder to get stuff, and when i look there, and that's when the PSO has the weird preset folder.
If i look on the instrument tab and look under Presence at the available sounds, then the PSO shows up without the preset folder and looks great :-)
Still odd though, but I'm happy :-)
by themaartian on Fri Feb 14, 2020 5:31 pm
Really sounds like a bug you ought to officially report.
And if it's not a bug, maybe we'll get some explanation/documentation.
Intel i7 3.4GHz, 16 GB RAM, 2 TB HD Win10 Home 64-bit PreSonus AudioBox 44VSL
Studio One 4 Pro NotionMelodyne 4 Studio SpectraLayers Pro 4 Guitar Pro 7
PreSonus FaderPort Nektar P6 M-Audio BX8 D2 Beyerdynamic DT 880 Pro
NI K9U XLN AK, AD2 AAS VS-2, GS-2, VA-2, EP-4, CP, OD Toontrack SD3, EZKeys
Users browsing this forum: No registered users and 18 guests
