MIDI Editing and Automation Nonsense
Posted: Mon Feb 03, 2020 12:20 pm
Presume its me but I have had constant workflow issues with MIDI recording and editing.For example:
1. I record some chords and notes from my keyboard using an organ sound (Reason Rack used). I then go back and record/overdub some Modulation wheel movements which simulates the Leslie on and off on the same track as the MIDI notes. Playback on those Arranger sections works perfectly, the Modulation wheel activated on the Reason Rack organ patch. Presumably the automation Mod Wheel data is recorded on a separate layer.
2. I try and copy that section to another Arranger section - but only the MIDI notes are copied, not the Mod wheel Automation information. Why not? Something to do with the layer?
3. I attempt to Merge the data on the track - but still it copies only the notes, not the Mod wheel. I presume it is the same for pitch bend.
4. The only soultion I can find is to Unpack Layers To Tracks, which places the Mod Wheel automation data on a separate track - the original track remains.
5. I then copy the original section to another Arranger section which only copies notes.
6. I then move the Unpacked Layer Mod Wheel data section to the notes only section in 5. above - and this seems to work with the notes and the Mod Wheel data in the new Arranger section now merged together.
But this seems a really clunky workaround - anyone know what is going wrong here? Why should I need to do this rather than a simple Option drag copy to another section?
