"Z" monitoring (low latency software monitoring) and dropout protection on audio channels is fine through the main mix output. But, it's not working on the cue mix (audio is delayed by the dropout protection buffer amount). From what I've read, it should.
Can anyone confirm that this is OK or a problem on their system?
I9900K 4.68 Ghz, Gigabyte Designaire MB, latest Win 10 build, Steinberg MR816X interface, Studio One 4.6.1
by robertgray3 on Sat Feb 01, 2020 6:11 pm
It works for me
Are you going through a bus? I feel like there was a bug where it doesn’t work when you’re going through some combination of bus routing
My feature requests (every vote helps!)
Mac OS X Mojave 10.14.6
Mac Pro (Late 2013)
3 GHz 8-Core Intel Xeon E5
32 GB 1066 MHz DDR3
Dual AMD FirePro D500 3072 MB
Quantum 2
by j0001s on Sun Feb 02, 2020 11:21 am
Thanks for confirming that it does work for you. I suspected it was system related.
I tried a test project that had only one track wired directly to the output, and I get the same behavior with the cue mix.
This is not the only Z monitoring bug I have. Instrument Z low latency monitoring flat out does not work for me. You play on the keyboard, and no notes play. Until 15 to 30 seconds later, where they start dribbling out. It does work fine if I either press a key on the plugin instrument's keyboard (if it has one), or the Querty keyboard.
I'll put in a bug report with Presonus for both. I'll also try another audio interface to see if it changes anything.
by mikemanthei on Sun Feb 02, 2020 12:25 pm
15 to 30 seconds? That is some extreme latency!
Presonus 1818VSL / Focusrite 18i20 / StudioLive 32S
24-core Ryzen 9. 32 GB RAM
Tascam US-2400
Faderport 8
Users browsing this forum: No registered users and 18 guests
