Apart from security and remote access is there any reason to purchase Win 10 Pro instead of Win 10 Home to run a DAW?
I'm moving from Mac.
Cheers
2011 iMac i5
16 gig Ram
High Sierra on External Thunderbolt SSD
Studio One Professional 4.6.1
Cubase 10.0.5
Logic Pro X 10.4.7
by leosutherland on Fri Jan 24, 2020 1:49 pm
Hi Kip
Well, I use Home for my system, personally I've never felt any need to go to Pro - I don't believe there is anything in Pro that will significantly enhance the usage or experience of S1 - Home works just fine for me.
Caveat, that is just my view - I could be completely wrong, I'm willing to be educated ;)
Not sure that really helps though :D
EDIT: you could go for Home, but then upgrade to Pro if it becomes necessary
...said Halo
Studio One Pro v4.6.1
Serum, Diva, Synthmaster, Massive, Syntronik Bully, MTron Pro, Kontakt/Reaktor Players+stuff, Xpand!2+AIEP3, KLC
Reference 4, Reverberate Core
3XS SQ170 Music Studio PC (Main DAW)
Windows 10 x64 (1903)
i7 8700 Hexcore 3.2GHz, 16GB DDR4-2666, 500GB Samsung 970 EVO M.2 NVMe SSD + 1TB SATA HD
Scarlett 2i4 (G2), Korg Taktile 25, Faderport 2018, ATOM
MSI GE62VR 7RF Apache Pro (Standby DAW)
Intel Core i7 7700HQ 2.8GHz, 16GB, 500GB Samsung 970 EVO M.2 NVMe SSD + Samsung 1TB 860 SATA III SSD
by darrenporter1 on Fri Jan 24, 2020 2:11 pm
Pro gives you the flexibility to not install Windows updates when they are released. This alone is worth it for many people.
Presonus 1810, FaderPort 8, Console 1, JBL 306P Mk.II Monitors, TASCAM US16x08
Hairball Copper, DIYRE CP5, Sound Skulptor CP5176, Peavey VMP-2, Suhr Reactive Load
by scottyo7 on Fri Jan 24, 2020 2:35 pm
Since the next major update of Studio One 5.X will only be supported on Windows 10, I'm pondering updating from Windows 8.1. :roll:
With Win10 Pro you still have to know how to change settings to 'block' updates.
But even with Win10 Home you now have more options on scheduling 'updates'.
And with some finagling per this article you can block near all of them.
But I'd ensure that the Win10 Security updates get installed. ;)
If you've not already done so... Please add your Signature & Gear Spec's to your Profile Here.
ASUS Laptop, i7 3820QM; 16GB; 2 Samsung 840 SSD's; NVIDIA GTX 670MX; Win 8.1.
S1 Pro 4.6.1; EZD2 2.1.8. Behringer UMC404HD USB A/I.
Synths: Alchemy, Air Tech Music Suite. Melodyne Studio 4.2.4. Ozone 5, (all 64bit).
Akai MPK249. 6 guitars. Eleven Rack, 2 Line 6 POD's & an E-bow.
Fluid Audio FX8 monitors; Dual 28" Displays. Rode NT1; SM58. Faderport;
-My Band: "2GUYZINABASEMENT"
-Just Me
by mikemanthei on Fri Jan 24, 2020 3:15 pm
I will Echo that a Windows update blocker is a critical piece no matter which one you decide to use. That and a tool like Windows Privacy Dashboard are the first two things that I install when building a PC.
Aside from that, I don't know of any differences between the two versions that would affect Studio One.
I have two computers running W10 and Studio One. One was upgraded from Windows 7 Home, so I will assume that the Windows 10 version is also "Home".
The other one was always Windows10. I think it's Windows 10 Pro but now that I think about it, I never really gave it much thought. :-) I guess that would help support the idea that it really doesn't make a difference.
Studio One v2, 3, and 4 Professional
Presonus 1818VSL / Focusrite 18i20 / StudioLive 32S
24-core Ryzen 9. 32 GB RAM
Tascam US-2400
Faderport 8
by Kip on Fri Jan 24, 2020 11:29 pm
Thank you all!
I guess I'll need to decide if turning off/delaying the Win update process is worth the extra $100.
I suppose as Leo suggests I could purchase Win 10 Home then pay for an upgrade after to Pro if need be.
2011 iMac i5
16 gig Ram
Cubase 10.0.5
Logic Pro X 10.4.7
by Jemusic on Sat Jan 25, 2020 12:11 am
I am in a similar situation. I have got Win 7 Home and will upgrade to Win 10 Home as well with a view to maybe upgrading to Pro later.
Because now the whole updating process is easier with Win 10 Pro and Home as well. You can delay an update now with Home at least until it is convenient to do so. Instead of in the middle of a session.
by Nip on Sat Jan 25, 2020 1:31 am
In network settings there should be a checkbox saying that you are using a metered connection - meaning it costs money. Nice enough MS allows you to postpone then until convenient.
Featured updates, like Creators update each spring or so, can be postponed for a year.
This is larger update, and can mean new drivers are needed and such - so good with this option.
https://www.windowscentral.com/how-dela ... 019-update
by stefanrauch1 on Sat Jan 25, 2020 4:05 am
I use (and do recommend) Sledgehammer 2.6 to stop automatic updates completely.
It also lets you manually install them whenever you feel the need to.
For big updates like Creators Updates, I temporarily uninstall Sledgehammer.
Free Download:
http://m.majorgeeks.com/files/details/wumt_wrapper_script.html
Hardware: Intel i7-5820K 32GB DDR4 RAM || XFX Radeon RX460 passive || UAD2 Octo & Duo PCIe
Peripherals: Fireface UFX II (+2x ADA8200) || Faderport Legacy || Atom || M-Audio Axiom
by Tacman7 on Sat Jan 25, 2020 8:31 am
My last computer purchase was a machine with win10 home on it. Strict DAW machine.
I really haven't had any problems with updates, they happen but haven't had any problems.
It's been two years.
I have to buy a new surf computer because TurboTax won't install on a win7 machine.
Oh woa is me
This is the new processor:
https://www.cpubenchmark.net/cpu.php?cp ... 00&id=3481
Melodyne Studio - Nectar Impact LX25+
Where 'IS' Shitcreek? and
by Kip on Sat Jan 25, 2020 10:03 am
stefanrauch1 wroteI use (and do recommend) Sledgehammer 2.6 to stop automatic updates completely.
Free Download:
Great recommendation! Thank you!
2011 iMac i5
16 gig Ram
Cubase 10.0.5
Logic Pro X 10.4.7
by PreAl on Mon Jan 27, 2020 9:28 pm
darrenporter1 wrotePro gives you the flexibility to not install Windows updates when they are released. This alone is worth it for many people.
Home also gives you that flexibility now:
https://www.howtogeek.com/410183/micros ... d-updates/
I absolutely would not recommend third party software stopping updates, not a good idea. Use what Microsoft provides.
Studio One Pro 4, Faderport 1, Atom, Focusrite Saffire Pro 40, Maschine Studio, Octapad SPD-30, Roland A300, Windows 10 Pro 64 bit, also running it on Mac OS Catalina via dual boot (experimental).
Intel i9 9900K, 32GB RAM,
Users browsing this forum: DJ_OXyGeNe_8 and 18 guests
