Hey Guys:
I'm working in Studio One 4.6 Professional. I got a copy of Plugin Alliance's DSM-V3 and installed it. I can open the folder it's installed in and see the dll. I have Studio One scanning that folder, but the plugins doesn't show up in the list of FX. I've installed, uninstalled, reset blacklist, rebooted etc. but it never shows up. I scanned the folder in Cakewalk Sonar and the plugin shows up fine there. I have other PA plugins and they scan fine. Can anybody give me an idea of how to fix this.
Thanks!
by Trucky on Tue Jan 21, 2020 8:56 am
I downloaded the 14 day trial and was able to install it successfully.
The VST3 should be installed in the "C:\Programs Files\Common Files\VST3" folder.
Here's some screenshots to compare with your installation. Hope this helps.
Windows 10 Pro 64-bit (1909), Studio One 4.6.1 Pro | Notion 6.5 | Universal Control v.3.1.2.54970
StudioLive Series III 32 v2.1.16522
by jrcurtis on Tue Jan 21, 2020 9:31 am
I'm not at computer so I'll try this tonight. I did change the folder where I put the DSM and that might be the problem. Thanks for the reply!!
by jrcurtis on Tue Jan 21, 2020 8:01 pm
I re-installed in that folder, but t still doesn't show up. The crazy part is it shows up in Cakewalk/Sonar.
Thanks very much for replying.
by Trucky on Tue Jan 21, 2020 8:19 pm
Can you post screenshots for your install as I did with mine?
by jrcurtis on Wed Jan 22, 2020 10:49 am
by jrcurtis on Wed Jan 22, 2020 10:50 am
Those images are out of order, but I hope you get the idea.
Many, many thanks for the help.
by Trucky on Wed Jan 22, 2020 1:38 pm
How about screenshots for VSTPlugins location and the Blacklist screen (Plug-in Manager) in Studio One?
by jrcurtis on Wed Jan 22, 2020 3:40 pm
Thanks for hanging tough with me!
This is the locations for S1 Version 3
DSM-V3 Shows up in version 3 but not 4. I think I'm using the same folders for both.
I'm baffled.
This is the locations folder for S1 Version 4
by Trucky on Wed Jan 22, 2020 3:58 pm
That's quite a few search paths that also include paths for 32-bit plugins!
However, I don't see the default (review my first response) for the VST3 plugin you want to install:
C:\Program Files\Common Files\VST3
by jrcurtis on Wed Jan 22, 2020 6:37 pm
I created a path to common files>vst3. I can see the dll in there, but when I scan it doesn't show up in S1 Version 4, but it does show up in S1 Version 3. It also shows up in SONAR. Is there something I need to do in Version 4 that I'm missing?
Thank you immensely for your help.
by Trucky on Wed Jan 22, 2020 8:25 pm
jrcurtis wroteI created a path to common files>vst3. I can see the dll in there, but when I scan it doesn't show up in S1 Version 4, but it does show up in S1 Version 3. It also shows up in SONAR. Is there something I need to do in Version 4 that I'm missing?
Based on the screenshot you posted it will be looking for a VST3 plugin (Not a VST2 dll)
I'm a big fan of reducing the number of search paths for VST plugins to reduce the time it takes Studio One to scan them.
Path for VST2 plugins:
C:\Program Files\VSTPlugins\
Path for VST3 plugins:
C:\Program Files\Common Files\VST3\
by jrcurtis on Wed Jan 22, 2020 9:02 pm
I can find the dll in c>program files>cakewalk>VStplugins. Does the dll need to be in the Common files>Vst3 folder?
Do you have any idea why Studio One 3 can find and list it, but version 4 can't it?
again, thanks!
by Trucky on Wed Jan 22, 2020 9:55 pm
jrcurtis wroteI can find the dll in c>program files>cakewalk>VStplugins. Does the dll need to be in the Common files>Vst3 folder?
That (.dll) is the VST2 and it must be left over from your previous installs. Look for the VST3.
Please review the details in my previous responses or pm me if you still are having problems.
by jrcurtis on Thu Jan 23, 2020 4:57 pm
You have been heroic in trying to help me, but nothing seems to help. What baffles me is studio 1 version 3 can find DSM, but Version 4 doesn't. Can you think of any reason why this would happen? If I could figure that out my problem would be solved.
by Trucky on Fri Jan 24, 2020 1:12 am
Both have different methods for scanning plugins. For me, scanning in Studio One 4 is faster. I really like the Plugin Manager.
The DSM-V3 VST3 plugin was easy to install for me. It works on both my laptop and desktop computers so at least I can confirm it works with Studio One Professional 4.6.1 on Windows 10 (1909). Why it doesn't work for you will require more troubleshooting. I didn't receive a pm from you so I'd recommend contacting support with the company you purchased the plugin for further assistance. Hopefully they can get it sorted out for you.
by jrcurtis on Fri Jan 24, 2020 10:07 am
I can't thank you enough for your help. It's truly appreciated. I do have a ticket in with PA and they are baffled as well. Obviously something is going on in my machine that's causing the problem, but who knows what that is.
Users browsing this forum: No registered users and 17 guests
