deleted post
What does your Performance Monitor show when you hear these?
Also, do you experience this when you record a new song?
deleted post
deleted post
Yes, if you hear the crackles, they will enter into the recording. Things can change up all the time, so don't think it's due to some Windows update, or your maintaining a consistent setup.
Let's target the high CPU for now. You'll also want to try Truckys advice on trying with a new song, and good practices/optimization link. OK, click the CPU meter along bottom transport bar. Check the open all plugins box. Then select at the CPU so it prioritizes highest to lowest cpu percentage for each plugin item. Go over that a little to gain an understanding of what plugins are causing the most drain. Particularly the 7% or higher plugins will be the culprits, but for now understand them, and deselect the few you can potentially do without for the next recording you want to make, that should eliminate some or all of the problem. 2nd, go to your audio interface and set its buffer to where you can record with a minimum of latency, but not so much that you get those crackles back. It's a bit of a learning curve, but in short, you'll be optimizing those immediate things. As you start new songs, gain an understanding of what plugins or instruments are a bit more weighty than others. 3rd, (probably should be first with priority) turn your internet, and/or Bluetooth off of your computer. That should greatly eliminate audio dropouts, and free up some resources. Swampthing wrote: Does anyone know why pops and clicks happen all of a sudden in playback, and what I might try to fix it? You haven't shown us your full equipment. Processor type, and drive type(s) might explain a lot. My guess is your computer may be just a bit on the fence as far as optimization goes (mine is, as it's now an 8 year old laptop, i7 Intel, with only one 1 Tbyte HDD 7200 rpm hard drive). However, it's been downright wonderful with a little foresight on watching buffers, thankfully a Presonus Audiobox VSL (very little latency), a lil' love such as backing up, and staying lean have kept my setup still in date for recording and production purposes. I can get 25 to 40 Stereo channels/tracks with little need to have to render audio, until of course it's just time to do so. Waves SSL, Schepps Omni, and other plugs on every channel. Add those few additional specs because we could be missing some part that would get you the best answer. As for now, it seems to be pay attention to what the individual plugins are, and define your buffer settings to immediate requirements. Happy New Year
Latencymon.
deleted post
So I downloaded that supposed cleaning thing, and now it's deleted 95% (400 files are missing!!!!!) of my tracks in the song. Wonderful. So it's gone from bad to most my tracks deleted. Apparently my tracks were recognised as stuff taking space that needed to be deleted. Probably it never does this to anyone else, but somehow it did it to me.
EDIT: I have had to do a whole system restore to get the missing files back, so I'm not downloading anything again. The pops and clicks are still there. My processor is 64x build. Anyone else have an idea of what to try? I have cleaned up the computer as much as I could, followed every step. Nothing's changed. Surely someone's had this happened to them before? As mentioned before, this has never happened before, so it's not like suddenly I have no space or anything. I hesitate to open a ticket because I usually have to wait for a week or more for a single reply, and I just don't have the time to waste (and no, can't call support. Not located in the USA, and have no millions to spare for calling overseas).
deleted post
I had a similar thing with Waves Element loaded once(just a few months ago).
If transport ran I got these cracks every couple of seconds. Midi to synth could even be muted so it did something strange. But in my case I saw nothing out of the ordinary in performance meter at all. It was just a test project for some purpose, so I just removed one thing at a time until it stopped and narrowed down to that synth. I had other external synths monitored so was part of audio stream - and if transport ran I got this, even with Element muted. Quickest way to do this is do save as - and removed half of synths - and see if it goes away. - if no, the do a new save as and remove half again - if yes, load saved and remove other half and continue save as on that. and so on. This halfing principle is fastest way. |
deleted post
I didn't explain that well, it was just a way to narrow down problem synth, if that is the case - not for permanent change of song.
Just a stepping stone to get closer to a solution. It may not be synths fault dispite this - it could be the way StudioOne handle it. I mean Waves element not even sounding for me - and create something like crackles in audio stream. Something in the core handling is my suspicion. They did some "optmization" earlier last year regarding synths - and synths does not always have the same workings internally. Some settings, like Reaper has, to turn off/on certain handling maybe. One way of optimizing cores does not fit all synths. Windows automatic handling of spreading threads over cores works pretty well. If to do own handling I think ability to turn that off if not working for everybody and all synths would be good. Maybe there is a parameter in preferences file somewhere to do that. But again, my issue might not be related to yours - having performance maxed out. I will test my project later again and see what I find now with 4.6. |
deleted post
swampthing wroteSo I downloaded that supposed cleaning thing, and now it's deleted 95% (400 files are missing!!!!!) of my tracks in the song. Wonderful. So it's gone from bad to most my tracks deleted. Apparently my tracks were recognised as stuff taking space that needed to be deleted. Probably it never does this to anyone else, but somehow it did it to me. I can't speak on the "Cleaning thing", and frankly, I would avoid turning your system upside down to fix a high CPU issue, so whatever that entailed is not where I'll be assisting. swampthing wroteThank you both, I'll try what you said tomorrow. However I still don't understand how I've never had any of these problems before... Forget the don't understand why it hasn't happened before. It's happened now. Something caused that. Your other check should be to view your Task manager for high percentage CPU/memory programs running in the background that could very well increase CPU/core distribution, etc. Along with seeing if you recently installed any software (even driver software) where the source may have included other trial, or Malware programs you didn't notice which could be running in the background. Those add on programs are unfortunate, but I'm only suggesting there are other circumstances involved if we're being realistic about differences, and troubleshooting properly. swampthing wrote: I can try to use fewer multi-instruments on new songs, but I don't want to delete tracks I've worked hard on just because they use too much CPU. Sorry if I missed that part. It doesn't appear to have been suggested in this thread to permanently use fewer multi instruments, or delete tracks. That's perposterous. Hey my friend, I understand completely when something isn't right, especially when trying to work on what matters to us, that it's frustrating if something isn't working in optimum fashion, or as you say, changes. We all experience it. Going forward. I hope you're not deleting tracks, multi instruments, and instead are reviewing where the CPU drain is coming from. That is going to be on your end, and there's enough information so far, imo to get your CPU down. Not by deleting anything, but looking at contributing factors. I also don't see the rest of your equipment specs that might help us assist further. All the best.
deleted post
@Lokeyfly
Swampthing seems to have solved his/her problem. It would be nice next time to know the specs.
deleted post
deleted post
I saw your specs in your sig just now, thanks 🙏 way to go !!
Users browsing this forum: No registered users and 50 guests
