Dear Studio One community,
we just updated with some little fixes. Here the official thread: viewtopic.php?f=151&t=36304 Happy discussion! Ari
Good grief! Already?
![]() Thanks for all the hard work, guys! ![]() Btw - FIRST!
...said Halo
Studio One Pro v4.6.2 Serum, Diva, Repro, Synthmaster, Massive (+X), Syntronik Bully, MTron Pro, Kontakt/Reaktor, Xpand!2+AIEP3, PPG Wave 3.V, KLC, Generate, Battery 4, CA2600 Reference 4, Reverberate Core 3XS SQ170 Music Studio PC Windows 10 x64 (1903) i7 8700 Hexcore 3.2GHz, 16GB DDR4-2666, 1TB 970 EVO M.2 NVMe SSD + 1TB SATA HD Scarlett 2i4 (G2), Korg Taktile 25, Faderport 2018, ATOM MSI GE62VR 7RF Apache Pro Windows 10 x64 (1903) Intel Core i7 7700HQ 2.8GHz, 16GB, 500GB 970 EVO M.2 NVMe SSD + 1TB 860 SATA III SSD Beyerdynamic DT990 Pros, JBL 305P II speakers |
Thanks for yet another update. However since doing so I am getting a Midi playback problem as in a long note is playing back as a short one. I understand this is an old chestnut and can confirm that when I move the note up one semitone underneath is a short midi note. This has only happened since this update so any help would be appreciated.
In the meantime I will check how I can re-install the previous version. Best, Gerry Just installed 4.5.3 and the problems remains. Maybe the update was just a coincidence but in either case I am now recording double notes, the played long one and underneath a short one is being added.
People who can't dance always blame the band.
https://soundcloud.com/gerry-cooper-855281238 Studio One 5 Pro. Windows 10 64 Bit 4 GB Intel 2 Quad Q 9950 @ 2.83 GHz . Focusrite Scarlett 2i2 3rd Genereation, NI Komplete Kontrol S61, NI Komplete 12 Ultimate, Izotope Ozone 5 and 8. Yamaha HS 80 Monitors. |
Quietly wroteThanks for yet another update. However since doing so I am getting a Midi playback problem as in a long note is playing back as a short one. I understand this is an old chestnut and can confirm that when I move the note up one semitone underneath is a short midi note. This has only happened since this update so any help would be appreciated. I'm not having this problem with MIDI notes with the 4.5.4 release. Does it happen for you in a newly created song? To revert back to the previous version, log in to your My.PreSonus account and choose the following: ![]()
Download the STUDIO ONE 5 PDF MANUAL. Access your MY.PRESONUS account. OVERVIEW of how to get your issue fixed or the steps to create a SUPPORT TICKET. Needs to include: 1) One Sentence Description 2) Expected Results 3) Actual Results 4) Steps to Reproduce. Windows 10 Pro 64-bit (20H2), Studio One 5.1.1 Pro | Notion 6.8 | Universal Control v3.4.0.61835 Dell Inspiron 17 5770 (Intel Core i7-8550U 1.8 GHz, 4GB AMD Radeon 530 Graphics, 16GB RAM, Samsung 860 EVO 2TB SSD StudioLive Series III 32 v2.4.17466 |
Thanks Trucky I found that but as above problem remains.
Its not a new song and I have previously recorded midi on it with no problems. I just wanted to add a midi instrument track today and this problem arose. Never ever happened before so I wrongly assumed the update was the problem but can confirm it isn't. Nothing else has changed on my PC and this is not happening in my other DAW's, that I no longer use.
@Quietly
Your specs show the NI Komplete Kontrol S61. Is this the device you're using for creating MIDI notes? What MIDI device did you add and setup for this in Studio One?
Trucky wrote@Quietly Hi Trucky midi input was All Inputs which I assume is its default setting switched it to S61 and problem resolved. Still not sure why this is happening though as I am pretty sure I have always had it set on All Inputs. I could be going quietly crazy though. Thanks for your help.
Quantize is global. But, each part of Studio One has it's own quantize setting. In other words, the Step Sequencer / Event Editor can be set to 16th notes while the tracks can be set to 8th notes. But yeah, as far as I know, the quantize you have set for the window you are working in is global. If you want to quantize only a certain part of a song, you can highlight just that section, or you can split it and quantize that section.
Win10x64 (Eng), Studio One 3.5 / 4.1, 32GB DDR4 RAM, Intel i7 5820, nVidia 960, Focusrite 18i8. Native Instruments Komplete Kontrol S88, Native Instruments Komplete Kontrol S61, Presonus FaderPort 8.
https://gregghart.hearnow.com/ |
simonthompson wroteSorry if in the wrong place, but is it possible to set different quantize settings on each bar? I.e. Could you have straight 16ths on bar 1 and 1/4 triplet on bar 2 or do you have to adjust every time? Is it definitely 'Quantise' or is it maybe 'Time signature' that you want to set for different bars?
Windows 10 Pro/i7 6800k @3.4Ghz/16Gb ram. Studio One Pro, Melodyne Editor 4, Vocalign Project, Superior Drummer 3, Izotope N2-O8 and various other plugins. Focusrite Saffire Pro 40, Faderport, Focal Alpha 50's, Korg Pa3x, Korg Pad Kontrol, numerous guitars, basses & other antiquated outboard gear.
After installing the latest version of S1, I have a problem exporting the song to the project. For example, I have several tracks in the song, some turned off (mute). When I export to the project, you can hear all the tracks - even the mutated ones.
It's troublesome because I have to try several times to make it work out and it will work one time ... but it lasts a long time. Please, improve this version.
CPU: GenuineIntel Intel(R) Core(TM) i7-2640M CPU @ 2.80GHz, RAM: 8098 MB total, AMD Radeon 6600M and 6700M Series, Intel(R) HD Graphics 3000, Windows 10 Professional (x64), Scarlett 18i8 USB, Studio One 3 Pro, Progression, NI Kontakt 5, Music Lab Real Guitar 3.1, iLok, Waves, Toontrack Music - EZdrummer 2, Melodyne,
jangok wroteAfter installing the latest version of S1, I have a problem exporting the song to the project. For example, I have several tracks in the song, some turned off (mute). When I export to the project, you can hear all the tracks - even the mutated ones. Are you saying this is a new issue?
Intel i9 9900K, 32GB RAM, EVGA Geforce 1070 (Nvidia drivers). Dell Inspiron 7591 (2 in 1) 16Gb. |
I can not see any current issue with song adding to new project. I guess he missed the function for updating the master file. So an already existing file is used. If there really is a new issue, please make a new ticket with steps to reproduce. Thanks a lot! Ari
jangok wroteAfter installing the latest version of S1, I have a problem exporting the song to the project. For example, I have several tracks in the song, some turned off (mute). When I export to the project, you can hear all the tracks - even the mutated ones. I also have not been able to export to the project page. I assumed that it was an isolated incident but now I’m not so sure. I have been using S1 since version 2 so I’d like to believe I’m pretty familiar with the process. This is definitely a new glitch. I was considering abandoning S1 for Mastering and just use my Ozone 8 or T Racks Suite because I just don’t feel like fighting with the program as I have also lost the ability to export to SoundCloud. |
Hi.
I'm having a problem since updating most recently. I cannot select a midi event in the track view. In this case, I am trying to alt drag an event onto another instrument track to have a duplicate. I cannot select the event to preposition it in the track. I can kind of select it by mousing across it. It won't copy and paste, but it will duplicate if I hit D. Everything duplicates when I 'duplicate track complete' but I still cannot select any of the events. I can edit everything in the edit window. Nothing else has changed on my system. Anyone else? Should I submit a support ticket? Thanks. |
lisarowe wroteHi. I reckon you might be in the combi tool mode. That's where the cursor switches to the arrow tool if you are in the lower half of the event and the range selection tool if you are in the upper half of the event. It confused the heck out of me the first time I accidentally did it but now I love the tool. It's a real time saver. The combi mode is selected with the square bracket to the left of the arrow tool on the top toolbar. Or it might not be that at all, in which case just ignore me!
Studio One Pro 4, Intel i5-8400 @ 2.8GHz, 32GB RAM, Windows 10 Pro 64-bit
Focusrite Scarlett 8i6 (3rd Gen), Novation Launchkey Mini Mk3, Akai MPK Mini MKII, Novation Remote 25 (ancient, but not as ancient as I am) Guitars, Mics, Synths, Upright Piano (tuned circa 2005), £50 drum kit, Wife (with Cello and Cello skills) |
lisarowe wroteHi. No way Me too |
frank.crow wrote I'm glad to hear this! I thought I was nuts for a day or two. I have since seen that after I closed S1 and later reopened one of the songs in question, everything worked just fine. I am going to spend some time recreating the issue, I guess. FWIW to other reply, Ian, I always have the multi/combi tool engaged, so the arrow should have automatically selected the event and an Alt drag would have done the right thing without issue. It's in my muscle memory pretty deeply. Thanks, though. : ) |
Users browsing this forum: tomslowcat and 48 guests
