Is there a compatible USB interface for the Behringer (U-Phoria UMC22 in particular) or do we have to use PreSonus interfaces strictly? ASIO4ALL is the recommended driver but I know that is NOT the way to go. I have downloaded all of the PreSonus drivers and Studio 1 kicks them out when I try to switch to them. Thanks for the advice, one way or the other!
BTW, I have checked to have my signature 'gear' attached but it doesn't show in the preview . . . I'll add if necessary later.
Mike Frandson
Studio One Artist version: 4.5.3.53866
HP 6300 Core i5-3570 3.4 ghz, 16G Ram, 64-bit
Windows 10 Pro build 18362.356
by wolfjames on Mon Sep 16, 2019 3:43 pm
Here is some information that may be helpful on setting up the Behringer interfaces.
Download & Install Driver Software
After registration, the next step is to download and install the required PC (Windows) driver. A driver isn’t necessary on a Mac OS because Behringer interfaces are class compliant and do not need additional software to connect. Follow the steps below to install the required driver software for Windows.
Download & Install Behringer Audio Interface Drivers
1. Visit Behringer’s Audio Interface page and select your product.
2. Click the Downloads tab and scroll down to Drivers. Click the latest available driver to start the download.
3. Open your Downloads folder, extract the .zip file, and run the .exe installer. Restart your computer after the installation completes.
Do I need to use the ASIO4All driver?
Although most Behringer audio interfaces have their own driver (version 4.38 as of July 2018), some of the smaller interfaces will require the third-party driver, ASIO4All. These interfaces include the UMC22, UM2, UCA222, and UCA202. Check out our ASIO4All setup guide for instructions on how to install and configure it.
by roblof on Tue Sep 17, 2019 8:59 am
I’ve checked with my contacts and the umc22 does not have an official asio driver from behringer.
You could perhaps try the generic low-latency driver from steinberg to see if that helps...?
by bruceqld on Tue Sep 17, 2019 4:20 pm
Very dissapointing that any company releases an audio interface with no asio drivers.
If you are running Windows 10, definitely give wasapi driver mode a try if asio4all is unsatisfactory.
Studio One 4 Pro, Win 10, Asus ROG i7, 32 Gb Ram, SSD, RME Fireface UFX, X32, Atom, Faderport USB
by klypeman on Tue Sep 17, 2019 7:07 pm
Try this and see if U can download drivers here : https://www.behringer.com/c/Behringer/D ... rans(en|en)
Moderator
Windows 10 64bit Home, Mac Catalina, SO4.6.1 Pro, LUNA, Cubase 10.5 Pro, SLIII32, 24.4.2, 16.0.2 FW, Faderport 8, Atom, UA Apollo Twin TB/USB, Toontrack, NI Komplete 12, ++
by IanM5 on Tue Sep 17, 2019 10:43 pm
I had very mixed results with a Behringer UCA222 and ASIO4ALL. It mostly worked except when it occasionally dropped out and needed re-plugging, and the ASIO Control Panel often disagreed with the settings in the DAW and changed on their own. I assumed this latter bit was normal until I got an interface with a "proper" ASIO driver". So it's cheap and cheerful and will mostly do the job but will occasionally annoy you! I've no regrets about replacing it with a more pricy Focusrite interface!
Studio One Pro 4.5, Intel i5-8400 @ 2.8GHz, 32GB RAM, Windows 10 Pro 64-bit
Focusrite Scarlett 8i6 (3rd Gen), Novation Launchkey Mini Mk3, Akai MPK Mini MKII,
Novation Remote 25 (ancient, but not as ancient as I am)
