good analogy with the vertigo switch
jBranam wrote You are a bit mistaken here. In fact VU's give a better and more accurate account of rms levels than peak. They are not a good indicator of peak at all. Also in the old days 0 dB VU referred to a voltage level. It was not the ceiling at all. There was always some headroom above 0 dB VU. (on a high quality mixer as much as 20 dB headroom above and from tape machines 12 to 15 db as well) So no 0 db VU is not like 0 dB FS at all, certainly not from the converters. O dB FS should be thought of as the absolute maximum.
SwitchBack wroteOne of the most common questions from newcomers to this forum is: “Why is my mix so quiet”. Understanding the problem is the first step towards solving it. And the same technical knowledge needed to really understand the output mix problem can be used to get more from the input converters too. It’s a choice The reason why peoples mixes are so quiet is because they are not mastering them properly. The solution is to record at healthy levels all the way through yes but not super loud either. Tracking and mixing are not the best times to be aiming for a loud mix. Your final mix may end up averaging -18 dB FS if you like. Keep your monitoring levels up while tracking and mixing. People monitor too quietly and then push levels during the mix to compensate. That is a mistake. If you don't have the option to monitor loud then you are not in the best position to be producing music. (Please note: for great mixies you need to monitor at all levels, very quiet, medium and loud!) Loud mixes come after the mixing process eg skilled mastering in getting them much louder. But these days at least we are now starting to realise that super loud mixes are also not the way to go. Common sense is starting to come back.
Jemusic wroteSwitchBack wroteOne of the most common questions from newcomers to this forum is: “Why is my mix so quiet”. Understanding the problem is the first step towards solving it. And the same technical knowledge needed to really understand the output mix problem can be used to get more from the input converters too. It’s a choice * Sigh... * |
i don't recall converters on old analog gear and as for 'peak' i know they were not a true indication of peak (most of what i wrote was referring to the past before this digital realm) VU meters were not a 'true' indication of anything imo lol
jBranam wrotei don't recall converters on old analog gear and as for 'peak' i know they were not a true indication of peak (most of what i wrote was referring to the past before this digital realm) VU meters were not a 'true' indication of anything imo lol Well Jay VU meters fall into several categories now. Hardware and software. And in the old days the hardware meters were either cheap or quality. So yes in a way you are right. A cheap VU may not tell much at all except a rough indicator of average level. Expensive ones however are different. They can in fact tell you a lot, and not just about levels either. But to keep this thread on topic, the main thing here is the main fader and its associated level meter. The main level meter is OK but does change its scale according to the type of metering one is doing. As long as the OP (and others) are happy with how the main meters are working now. I think one of the good things that has been added is Peak/rms (and Peak hold) metering on all channels now and that is easy to forget. This only improves channel metering and tells you more.
Users browsing this forum: jebbyslonar and 57 guests
