I wish to create focus midi mapping for my Acorn Masterkey 49 keyboard controler
I use SO 3.56, Artist OEM (came with a Acorn Masterkey 49 - & been using it for quite a while. I have read the manual, read replies by Lawrence, Niles & Trucky concerning mapping the NanoKontrol2, Nectar & other controllers & I note that the Presonus PS49 is also a Acorn Masterkey keyboard & that the PS49 has a .surfacedata file that has been set up to allow focus mapping for many virtual instruments and effects. - I would like to do this with the Masterkey 49 ! I have a couple of problems, 1] I can create a new keyboard controller see in in Studio one, & midi learn the 4 nobs and one slider if I go to the local Focus / Global window and map the Masterkey 49 keyboard it will map, using a virtual instrument, if I click the cog(turns blue) and then click the Control drop-down list and chose my keyboard The the External Devices window opens and states Focus or Global correctly if focus(yellow) or global not yellow) but, Every time I got to a different instrument from Mai Tai to Presence the display shows that the keyboard's knobs and sliders are already mapped for the Mai Tai or what ever, if i change them they are globally changed regardless of the Focus/Global settings Am I doing something wrong, or missing something - I note the directories of surfacedata & surfacedata1 in Users...../Roaming\PreSonus\Studio One 3 I actually use a location E:\Studio One\UserData set in Options/Locations user data - changing it does not seem to make a difference 2] And is it therefore also possible to use a .surfacedata file from the PS49 for the Masterkey 49 by changing the Gui-Id ? Am I trying to do something SO3.56 Artist won't do ? Does So4 Artist/Pro allow this to function properly ? Your help and suggestions would be appreciated Thanks David |
I have solved one of the problems -1] Global/Focus mapping Studio One Artist 3.56 does not seem to save Mapping setting until you shut down - so I have had to map one instrument then siup down and reopen the DAW
I have not yet gotten the PS49 settings to work by changing the GUI ID to the Nectar/Acorn Masterkey's GUI- ID |
Users browsing this forum: No registered users and 110 guests
