Plug in the guitar into the audiobox i2 and can hear the guitar thru the monitors. When I click on Ampire none of the cabinets or effects work.
by Bbd on Tue Aug 20, 2019 9:09 pm
Open a support ticket.
Bbd
by Tacman7 on Wed Aug 21, 2019 8:12 am
You need to put your system specs in your signature.
Describe your problem, what you did, what you tried, etc.
Learn how your interface works, the internal routing. It probably has a zero latency feature which is direct monitoring.
So you plug in you guitar to the interface then it will send it right to the output that you hear.
You have to turn that off and monitor through S1, through the track you created with the insert on it. Monitor button has to be on to hear anything through a track.
Then you would hear that effect.
Melodyne Studio - Nectar Impact LX25+
Where 'IS' Shitcreek? and
Users browsing this forum: stuman and 12 guests
