Adding Tempo Change Point via Mouse Without Moving Previous Tempo
Posted: Tue Aug 20, 2019 4:08 am
by prashantmishra1
Hey everyone. I have a query for which I couldn't find the answer anywhere yet.
While using the Insert Tempo Change via Mouse, the tempo point sometimes moves up or down. Is there a way to restrict cursor movement while clicking on the Tempo track?
I know the alternative is to use the + button but I wanted to know if it's possible via mouse click with restricted movement.
If this isn't possible yet, it'd be great to have it in the coming updates.
Thanks.
Re: Adding Tempo Change Point via Mouse Without Moving Previous Tempo
Posted: Tue Aug 20, 2019 5:22 am
by Nip
I think this goes for tempo track as well, also like automation.
"It is also possible to float the Arrow tool over an envelope point and then hold [Alt]/[Option] and scroll the mouse wheel up or down to increase or decrease the value of the point (that is, move it along the vertical axis)."
You can also use Ctrl to restrict movement i either direction depending on distance while dragging.
