I have a FabFilter TP Limiter and all was working before the latest update. Now my before limit is 2.7 and my after is 2.2.
The limiter is set to 3.3, which has always kept it at 3 or better. Is this an issue ? I tested with an a few older files that I have not touched in several month. Studio One Pro 4.5.2 Thanks |
Have you unibstalled/re-installed the plugin? Have you posted this problem on FabFilter's forum?
Is your limiter in its normal full operating mode or has it gone back to demo mode. I have had a few issues with some of my 3rd party plugins reverting back to demo mode (or not working at all) after a Studio One update. Seems like with some plugins, the Studio One update is messing with licences etc.. May not be in this case but worth checking.
If its so, then the solution is just reauthorise the plugin and it goes back to normal. Un-installing and re-installing may not be necessary but it would not hurt either.
OK So I reverted back to a 4.0 and its still not working right. Its just not Limiting.
Attached are the two images After I ran Detect Loudness. |
Full uninstall.
Then install latest version.
Users browsing this forum: Tacman7 and 97 guests
