Jemusic wroteThat Negative Delay plugin is Windows only but a good work around in the meantime. It has been reported so we do know about this issue and it will be addressed. Hi jemusic, Thanks for the feedback. I'm using the free minusdelay VST plug-in to remedy this issue, and it does work. It would be great to see this issue fixed by Presonus, I just upgraded to Studio One Pro 5, and love this DAW, but please, please, Presonus fix this issue, the sooner the better. |
Just wow - I was noticing this on V4 last week and was scratching my head a bit and then I decided to ignore it...
So here is another reason to update to V5.
Can't reproduce this here. I haven't had any issues with negative track delay since the fix in 2020. Working fine here.
Can you please provide any steps to reproduce these problems or videos that show the wrong behavior?
Lukas Ruschitzka
.. and please put your specs in your signature. I would also review and study the entire thread,.it may offer a solution.
I'm on macOS 12.3.1 2019 MBP 16, i7, 64gb ram using S1 5.5.2 and the latest version of Kontakt as a VST3 (not AU). With Areia Strings ( Audio Imperia ) loaded on a track, I set the recommended negative delay to -123 ms, then I test with a fast 16th note pattern, from bar 1 it plays in sync, but when I start form further down the timeline, say bar 10 the playback is scrambled, notes are missing and out of sync. This is also the case if I copy, say a 4 bar clip, to a position later in the timeline. The same issues occur with other libraries using Kontakt i.e Cinematic Studio Strings. I haven't tested Spitfire or Sine players yet.
I hope this makes my situation clearer. |
Is this only during playback or are mixdowns affected as well?
Which audio interface do you use? And what is your buffer size?
Lukas Ruschitzka
[email protected] wroteIs anyone still having issues with negative delay on midi tracks ? Just upgraded to S1 v6 and Negative delay seems to be behaving. Full specs in your signature please.if that's OK. If you've gone through this thread you will notice there seems to be two different behaviours for windows and Mac, and it's not that widespread any more (and apparently fixed). Please check through it all to make sure you've tried the suggestions.
Users browsing this forum: jazzundso, johndoe313, pawelhebda and 13 guests
