Hi friends.
All of a sudden. My undo stopped working. it doesnt matter if it´s from the dropdown edit menu or key command (cmd+Z). If I move a clip in the arrange, and instantly undo it, it works. When looking at the undo history it says "Undo moving event" However, as soon as I move a clip and press play after moving the clip, the undo doesnt work anymore. It doesnt matter what parameter I change. As soon as I hit play, it forgets what has been done and no Undo/Redo works. When checking undo history, instead of saying "Undo moving event" it says "Undo multiple parameters" and nothing happends when undoing. It does not undo any parameter what so ever... Is there a secret button that I accidentalöy pushed or W T-F happened? Pleeeasseee help me! Thank you for your time. //Ted |
Ted,
You need to give us your specs! No idea what version or operating system you are on. We might be able to help if you provide this info. |
I don't know how far along you are in your project or how many tracks you're using, but it might be a good idea to close your song file, start a new file, and then import all your valuable tracks into that new project. (Import Song Data - under song menu).
That way you are not being held back by what might be a corrupt file. I have encountered glitches as well that were often file-specific. It's better to start a new file than lose time swimming against the tide. tedkrotkiewski wroteOk, Thanks.
tedkrotkiewski wroteHi friends. Yeah. This has happened to me several times as well, always toward the end of a long session. I was too busy to report it. Glad you brought it up. Haven't seen it yet in 4.5 (fingers crossed). |
Next time this comes up take a look at your undo history. I think there’s one or two features that sometimes put duplicate entries in your undo history so it will appear for one or two undos that it isn’t working
Win 10 S1 4.5
Did about 45 minutes of testing a new song and creating, editing, deleting with Undo. Had one system crash that I will report. But could not get undo to mess up afterwards. The problem could be caused by a number of moves that then turn off your Undo. So far, I have not seen that. Will keep an eye out for it. Robert asked you to keep us updated. Please do. |
robertgray3 wroteNext time this comes up take a look at your undo history. I think there’s one or two features that sometimes put duplicate entries in your undo history so it will appear for one or two undos that it isn’t working It's not like that. I could save, quit, reboot the entire system, reload the session, and undo would still be broken. But only in that particular session. Others would work fine. |
The undo history stays the next time you open the session. So if there are, say, 20 dummy entries in the undo history you would have to press it 21 times. If this is still happening with a session, can you post it?
robertgray3 wroteThe undo history stays the next time you open the session. So if there are, say, 20 dummy entries in the undo history you would have to press it 21 times. If this is still happening with a session, can you post it? Sure. |
wonder6oy wroterobertgray3 wroteThe undo history stays the next time you open the session. So if there are, say, 20 dummy entries in the undo history you would have to press it 21 times. If this is still happening with a session, can you post it? Apparently this is still a bug in Version 5 (Mac OS), and something I had not previously had an issue with before. A new song will have no issue. To me it appears that if you create a new song with stems from another DAW - in my case Logic Pro X - after a while UNDO stops working. I don't know why, but this has happened a couple of times to me now in the new version and always bringing in stems from another DAW. |
georgeheredia wroteApparently this is still a bug in Version 5 What does your undo history say? A recent time that I saw this "bug" the person had izotope RX in Adaptive mode and it was creating hundreds of undo history entries. |
Same here. First time I encountered this is on a session in v5. Interesting.
EDIT: So here is what I found out was causing my issue. I had the Eventide H3000 on a send/return for a couple tracks. The preset I used in the plugin had constant pitch shifting parameters ever so slightly. This was registered as a plugin parameter change in S1. I noticed in the top left corner of the DAW. This would normally be an undo-able function so S1 is recording it as such. This makes undo impossible. My history was blank, though. So I am wondering is there an undo-disable on a per-plugin basis or something? I can use the same preset in other DAW's and it doesn't do that. Must be because of S1 being advanced and really integrating with all plugs and parameters. |
Can confirm this issue is present in v5. Was working on a new song file with just a few things in it. Undo's now have to be performed by opening the Undo history and selecting an entry. I undo all the time, and I think we all do. It's vital that it works when experimenting.
I have a dedicated music PC with i9 processor, 32gb of ram, nice fast system. |
I did a process by elimination, deleting insert after insert, and found that removing a particular plugin restored the Undo functionality.
In my case it was the Fat2 plugin by Soundspot. It's a modulation filter and I guess every time it adjust a parameter, it overwhelms Studio One's Undo functionality. |
The fact that FAT2 cutoff frequency is oscillating wildly is troubling. Either remove, dissable it, or filter it, and see if the problem goes away. Preferably for now, remove the fat channal on that channel altogether. It likely wasn't in your new song that had undo history working fine. That is probably over flowing your undo history with a bunch of data. Also check that you don't have a mod wheel or controller parameter slightly on that is causing that cutoff frequency to oscillate. Is your MIDI indicator constantly reading on even when notes aren't played? If so, when you remove the FAT2, does it go away?
It seems anyway, there may lie the culprit.
The problem there isn't that Undo needs to be disabled, the issue is that Control Link seems to be particularly sensitive to parameter automation coming out of plugins, whether or not the user is actively causing it.
A plugin that fills up the undo history is usually the most visible way this gets in the way, but it's not the only way. Many plugins can hijack Link mode on any of the Faderports if "Last Touched" is enabled. I believe if you place any AU or VST2 instrument (maybe inserts too?) in a Multi Instrument then even things like pressing the Sustain Pedal will cause this issue. |
Thanks for your replies!
I removed the Fat2 plugin and all is well in the kingdom. So, it wasn't a Studio One issue after all. I have lots of plugins that are fairly animated and lively, but that don't wreak havoc on my Undo history, so this was a Soundspot issue. |
Of course, no one was saying to dissable undo. The fact that undo might be inundated with some repeated or oscillation such as the cutoff frequency is worth disabling that parameter is and was worth looking at. No, disabling undo wasn't mentioned.
Way to go kristoferkristensen! Removing each insert helps reduce the possibilities of the snag Undo might have been encountering. Good it's solved! Yes, some plugin features don't adhere to Undo, or vise versa which can stop or defeat the Undo history chain. Most any plugin that isn't recognized by control link might be suspect. Though I've come across many that don't impact Undo.
Users browsing this forum: No registered users and 60 guests
