45 postsPage 3 of 3
1, 2, 3
I found a workaround (for me anyway).
Put all the waveshells in the VST3 folder into their own folder (say "Waveshells").
Then, when you want to burn a DDP image, move that folder somewhere else (of course you can't use vst3 waves plugins but vst2 ones still work)
Now you can burn an DDP image.
Don't forget to move the "Waveshell" folder back when you're done.
Presonus:
Surely this can be addressed?
by carlman on Fri Mar 27, 2020 7:39 am
I have the same problem in the last version of 3. Has this issue been fixed in v4?
by Bbd on Fri Mar 27, 2020 8:05 am
Try downloading the latest version of Studio One in a new folder and test. If you don't like it, you can go back to your normal install.
Bbd
by carlman on Fri Mar 27, 2020 12:24 pm
I demoed 4 a while ago so I can't try it again. Some said Cd burning in 4 works, others say it doesn't. Did it actually get fixed by now or is the problem still user dependent (on Win 10 here btw)
by echopark on Sun May 10, 2020 8:27 am
I had this "CD Burning service not installed" problem with Studio One 2.6.5. Someone had given the tip with vst 3 shells. It worked for me. Apparently the files WaveShell1.vst3 - WaveShell6.vst3 from Waves caused this burning problem. As soon as I remove them from the VST3 folder everything works again.
45 postsPage 3 of 3
1, 2, 3
Users browsing this forum: AriAhrendt, BobF, garybowling and 21 guests
