kerryvance wroteMy resolution is set for 1920 x 1200 (recommended) and yes, all 8 of the color groups are displayed. When I try loading the Default Set, nothing happensA display resolution of 1920 × 1200 pixels provides a 16:10 screen aspect ratio. A display resolution of 1920 × 1080 pixels provides a 16:9 screen aspect ratio. The reason I asked for your screen resolution is because Studio One will make adjustments to what's displayed based on screen resolution. I'm not sure why it's not working for you but don't have a way to test a 1920 x 1200 resolution. Maybe someone who does can confirm here that the Track Colors toolbar works for them. Another thing to try would be to delete the "trackcolors.package" file from the Scripts folder and re add it. Download it again if you think it may be corrupted. Be sure to close out of Studio One when you do this! kerryvance wrote (I tried uploading a larger jpg and got a dialog box telling me the maximum size had to be no more than 800 pixels wide and 600 pixels high).I'm not sure what you mean by trying to upload a larger jpg file? The Tracks Colors toolbar allows you to import a color template (Color Set or Hex Colors) but they are simple text files (not images). Example Hex Colors File *** Any line with an asterisk will be ignored 000000 000033 000066 000099 0000cc *** Make note, blue, red, whatever 0000ff 003300 003333 003366 003399 *** Make note 0033cc 0033ff 006600 006633 006666 *** Make note 006699 0066cc 0066ff 009900 009933 *** Make note 009966 009999 0099cc 0099ff 00cc00 *** Make note 00cc33 00cc66 00cc99 00cccc 00ccff *** Make note 990000 990033 990066 990099 9900cc *** Make note 9900ff 993300 993333 993366 993399
Download the STUDIO ONE 5 PDF MANUAL. Access your MY.PRESONUS account. OVERVIEW of how to get your issue fixed or the steps to create a SUPPORT TICKET. Needs to include: 1) One Sentence Description 2) Expected Results 3) Actual Results 4) Steps to Reproduce. Windows 10 Pro 64-bit (20H2), Studio One 5.1.2 Pro | Notion 6.8 | Universal Control v3.4.0.61835 Dell Inspiron 17 5770 (Intel Core i7-8550U 1.8 GHz, 4GB AMD Radeon 530 Graphics, 16GB RAM, Samsung 860 EVO 2TB SSD StudioLive Series III 32 v2.4.17466 |
Thank you again, Trucky. The jpgs that I was trying to upload were just my effort to show you what things look like in Studio One when I am trying to get the colors toolbar to work.
Jemusic wroteI have just checked this and it is all OK. Download the package, put it inside your scripts folder (inside the Presonus folder) Reboot Studio One and it should all be there. Help, Last week i was able to install Lawrence's color pack and it worked well. Somehow it is gone now. Reinstalled today, i see its in the Scripts folder - but does not appear after restart on my current song. Started an new empty song restarted the whole computer and it does not appear there either. any help would be greatly appreciated thanks |
Jemusic wroteI have just checked this and it is all OK. Download the package, put it inside your scripts folder (inside the Presonus folder) Reboot Studio One and it should all be there. Thank You very much, it worked the 4th time i cycled thru the whole process. I appreciate your quick response. |
Trucky wroteNow that I've attempted to use this script, I realize I didn't ask this in enough detail. The answer I got pages back that these colors can't be applied to console tracks was correct. Unless a console track is also represented in the arranger, these colors can NOT be applied, unless someone can explain something I'm missing. But I cannot select a console track and apply these colors.BezowinZ wroteI currently have tracks, events and channels colored with the sub par options available and would like to keep with that theme. My "problem" is I have multi-output VI tracks that show in the console by default, but not in the arranger. Adding automation to them so they show in the arranger, only to have to take additional steps to hide them in folders is more work than it's worth, especially since... Though these colors are better, they don't solve a secondary problem I have with there not being enough difference between colors. Though I've experimented to address it, I'm sure there's something about my appearance settings that contributes to this. As of now, I have to go 2 shades away to see the SLIGHTEST difference. The colors don't appear on my tracks as they do on the "color wheel". I hope Presonus addresses the 1st issue at some point. Or is it the script? I hope I can figure out how to address the 2nd issue. |
Hi Lawrence,
Noticed this Track Colors toolbar was posted a little over a year ago. Downloaded and installed it on my Mac. Does what it says on the tin. Especially useful if one develops his/her own custom hex sets. Very helpful. Thanks very much indeed. Just discovered how the "E" (Color only selected events) button works. That's a feature I use often. Excellent. I understand the use of hex to define a color set, e.g. the X11 color set. But how is the "color set" file, referred to in Import and Export Color Set different? Are these RGB or sRGB color sets using triple digit decimal numbers? Or is this a different color set, but also using hex? Could you please post an example of the "color set" file? And finally, what is the master color set used in Studio One? Is it X11 or something else? What set will be read accurately? The toolbar app is great. I just need some info to develop my own sub-pallete for the way I use S1. Again, thanks very much, Wayne |
Couple o' more quick comments/questions:
1. How do I open the RGB adjustment panel on Mac? I just opened it accidentally, and love it. But can't seem to repeat the functionality. Please and thanks. -> Found it! Left click the black bar above the color swatch. Lightening the darkest swatches makes them all visible and offers virtually limitless choice. 2. This might help some who are having issues with screen resolution. I just discovered that the color toolbar is detachable. Which means it can be moved anywhere on the display. Bonus! I don't know how easy or difficult it is, but one further improvement might be to make the detached window display either horizontal or vertical by dragging a corner or end. It wouldn't have to freely resize, just flip between horizontal and vertical, since the amount of content doesn't vary. That said, Lawrence, I understand if it's not worth your valuable time at this point. 3. One issue I'm having is not being able to see the darkest colors, usually the leftmost two in a group. I thought maybe making the toolbar background lighter might help, but it doesn't show through the color swatches, so no difference. The problem seems to be that the black borders around each swatch blend with the toolbar background. Could they be easily made white? This would give better definition to the individual swatches. Edit: The solution from #1 helps this. Although a lighter border around each swatch would still be a good idea imho. ![]() I apologize for the asks, Lawrence, and completely understand if neither is doable right now. I so appreciate the work you've put into this so far, and to offer it to S1 users for free, is incredibly magnanimous. Not to mention resourceful. Thank you, again. |
Just discovered now, amazing work.
@Trucky, I have dowloaded your other daws hex zip, I love it, but i think something is wrong. The file loads fine, but only 3, 4 or 5 groups of colors loads, the rest of colors are on a grey color, like missing colors issue. If I open with notepad for example the Cubase hex color files, appears that: *** Cubase Default Hex Track Colors (1-16) *** Group 1 e63737 e67837 e6bb3b d5e94c 8ee637 *** Group 2 4fd93c 35de5f 33d799 30cccc 40a9e9 *** Group 3 5e81eb 776aee a056eb ce44e6 e637ba *** Group 4 e6377c 42464c 42464c 42464c 42464c *** Group 5 42464c 42464c 42464c 42464c 42464c *** Group 6 42464c 42464c 42464c 42464c 42464c *** Group 7 42464c 42464c 42464c 42464c 42464c *** Group 8 42464c 42464c 42464c 42464c 42464c In other words, from second line of group 4, "42464c" color repeats to the final line of group 8. Am I missing something? I think your idea is pretty, the colours (for Cubase, Logic, Ableton, ProTools) looks very nice and close to originals, but I want the rest of the colors. What can I do? Thanks dude.
Windows 10 - Amd Ryzen 2600 - 16gb Trident Z Ram @3200mhz - Nvidia Gtx 1060 6Gb - 512Gb SSD + 2Tb Hdd
Solid State Logic SSL2 - Ableton Push - Krk Rokit 5 G4 - Beyerdynamic Dt 990 Pro - Audio Technica ATH-M30x - Behringer Ha400 Rode Nt1-A - Nektar Impact LX49+ - Presonus Faderport V2 - Behringer BCR2000 |
That's because at the time I did this, those DAWs had less than 40 colors in their color pallet.
Recently updated to Studio one 5 and the .package is throwing an exception when I open any project, and then when I close studio one 5, does any one else have this issue in version 5 and possibly a fix? It's the error reported in above post, scripting in panel.js. Should also add this is on mac OSX Mojave, Haven't checked it on windows. Thx.
franksaraceno@msn.com wroteRecently updated to Studio one 5 and the .package is throwing an exception when I open any project, and then when I close studio one 5, does any one else have this issue in version 5 and possibly a fix? It's the error reported in above post, scripting in panel.js. Should also add this is on mac OSX Mojave, Haven't checked it on windows. Thx. It may be a Mac issue as it works fine for me on Windows 10 (2004).
Man, I sure wish Presonus would just give us total control of track colors. I would REALLY like to be able to have less saturated, less opaque, more pastel background colors on tracks. The current track colors are so harsh and rude.
rodshort wroteMan, I sure wish Presonus would just give us total control of track colors. I would REALLY like to be able to have less saturated, less opaque, more pastel background colors on tracks. The current track colors are so harsh and rude. You should probably vote for this on the suggestions page - although Presonus don't regard colours as a "serious" issue and seem to ignore the requests - witness the confused order of colours in the colour palette. Hence having to use the Track Colours package kindly provided by the user.
____________ iMac 27" 3.3 GHz Intel Core i5, 32 GB Ram, Mojave OS 10.14.6, 64 bit, Studio One 5 Professional (always the latest) , Reason 11, Melodyne 5 Editor, Digital Performer 10, Korg Legacy Wavestation and M1, Arturia minimoog V, Helix Native 1.93, Bias FX 2 Elite, Superior Drummer 3, EZkeys, EZbass, Alesis Q49, Audient iD14, Faderport 2018, Gibson Les Paul Standard, James Tyler Variax JTV-59 and other gear. |
I really, really, really like having this visual flexibility. Helps me to see things in a much more organized way. For me, aesthetic is as important as the workflow. It's all about inspiration and this definitely helps. Thanks! Now comes the request...any way you could add a Saturation slider? I love having loads of color choices and pallets. But I prefer they be subtle. I turn my display brilliance way down to mellow the screen. And I think adding a Sat slider to this sweet little unsung gem of a script would round it out nicely. Whuddyasay?
artjohnson wroteI really, really, really like having this visual flexibility. Helps me to see things in a much more organized way. For me, aesthetic is as important as the workflow. It's all about inspiration and this definitely helps. Thanks! Now comes the request...any way you could add a Saturation slider? I love having loads of color choices and pallets. But I prefer they be subtle. I turn my display brilliance way down to mellow the screen. And I think adding a Sat slider to this sweet little unsung gem of a script would round it out nicely. Whuddyasay? OK. I'm curious to see what 40 colors you've picked for your Color Set? Please upload and share your color set file here.
Please upload and share your color set file here.[/quote] I just dropped the script into Studio 5 yesterday evening. made a couple of tweaks to be...I don't know..."amazed" I might say, and then I had to work the song. Unfortunately this song had only five tracks, so the colorizing and organizing will come later. I have plenty to mix, some band-like, some orchestral, so there will be loads of choices to make and "set". On top of that, I'm slow and have a tendency to change my mind. Soon as I can, I'll gladly share. Would love to have a "Sat" slider to make it even more "official." Thanks for this. |
Lawrence wroteHere's a toolbar add-on that allows you to create, store, import and export custom color sets of 40 colors using any RGB colors to color tracks or events. Hi Great and mighty Lawrence, can you make the 'Only Color Selected Events' toggle-button available as a Keycommand ( The 'E' button on the Track Color Panel.) That way, we can have two Macros like this. 1. Macro 1 (named, 'Color Tracks') a. View|Colour Tool Bar (Argument = 1) 2. Macro 2 (Named, 'Color Event') a. View|Colour Tool Bar (Argument = 1) b. Event|Only Color Selected Events (argument = 1) |
Users browsing this forum: No registered users and 41 guests
