The tweed wroteHi Lawrence, Found It! Have a good day, everyone!
-- The Tweed Band: https://www.fb.com/Tweed.Is
I downloaded the package a few months ago and it showed up in Studio One 3. For some reason, it's not showing up in the latest version of SO1 4 after installation attempt.
Go figure. Redownloaded from original thread and reinstalled numerous times without success.. Any ideas? Thanks! |
I have just checked this and it is all OK. Download the package, put it inside your scripts folder (inside the Presonus folder) Reboot Studio One and it should all be there.
Note when you update Studio One, these extra scripts can get wiped out for some reason and they revert back to the install scripts. After an update you may need to put them back in.
Search the STUDIO ONE 4 ONLINE MANUAL. Access your MY.PRESONUS account. OVERVIEW of how to get your issue fixed or the steps to create a SUPPORT TICKET. Needs to include: 1) One Sentence Description 2) Expected Results 3) Actual Results 4) Steps to Reproduce. Specs i5-2500K 3.5 Ghz-8 Gb RAM-Win 7 64 bit - ATI Radeon HD6900 Series - RME HDSP9632 - Midex 8 Midi interface - Faderport 2/8 - Atom Pad- iMac 2.5Ghz Core i5 - High Sierra 10.13.6 - Focusrite Clarett 2 Pre & Scarlett 18i20. Studio One V5.1 (Mac), Notion 6.7, Ableton Live 10 Suite, LaunchPad Pro |
Thanks for the reply... When I tried to install, I had already updated Studio One to the latest build. I will try to install the package again to see if anything has changed. I would like to avoid reinstalling S1 if possible, but I guess I could if need be. Though it originally installed correctly in S1 3.5, now it doesn't work in S1 3 or 4...
Fingers crossed... Salud! |
Being new to S1, I’m a bit confused. These won’t work on non-instrument/audio tracks in the console? Will these work on the multi-output tracks from a drum VI, for example? Busses, FX, etc?
BezowinZ wroteBeing new to S1, I’m a bit confused. These won’t work on non-instrument/audio tracks in the console? Will these work on the multi-output tracks from a drum VI, for example? Busses, FX, etc? While you in the arrange window you can simply apply these colours from this package to the tracks. All the tracks in the mixer will reflect the changes made in arrange. Colouring multiple outputs from a single VST in the mixer view only seems only possible using the normal colour palette.
In case anyone is interested, I've made a custom color set, spreading the colors around the color circle (45° increments) and, for each color, starting with 50% brightness and 100% saturation, then 75% B 100% S, 100% of each, 100% B 75% S and finally 100% B 50% S. Here is the result:
![]() If you want to use it, simply copy the text below and paste it in a text file somewhere on your computer; then, in S1, open Lawrence's color bar, select "Import hex colors" in the menu and point it to that text file. Done! * 0° 800000 bf0000 ff0000 ff4040 ff8080 * 45° 806000 bf8f00 ffbf00 ffcf40 ffdf80 * 90° 408000 60bf00 80ff00 9fff40 bfff80 * 135° 008020 00bf30 00ff40 40ff70 80ff9f * 180° 008080 00bfbf 00ffff 40ffff 80ffff * 225° 002080 0030bf 0040ff 4070ff 809fff * 270° 400080 6000bf 8000ff 9f40ff bf80ff * 315° 800060 bf008f ff00bf ff40cf ff80df |
Nice - thanks
____________ iMac 27" 3.3 GHz Intel Core i5, 32 GB Ram, Mojave OS 10.14.6, 64 bit, Studio One 5 Professional (always the latest) , Reason 11, Melodyne 5 Editor, Digital Performer 10, Korg Legacy Wavestation and M1, Arturia minimoog V, Helix Native 1.93, Bias FX 2 Elite, Superior Drummer 3, EZkeys, EZbass, Alesis Q49, Audient iD14, Faderport 2018, Gibson Les Paul Standard, James Tyler Variax JTV-59 and other gear. |
Jemusic wroteDamn. I want my related outputs the same color as my instrument & bus tracks. I’ll stick with the default options for now.BezowinZ wroteBeing new to S1, I’m a bit confused. These won’t work on non-instrument/audio tracks in the console? Will these work on the multi-output tracks from a drum VI, for example? Busses, FX, etc? Not sure what I did differently, but too many of my track colors look too similar. I thought it was the dark background, but it looks much better in vids with the same dark background. |
How could I miss this for half a year?
That is way cool, Lawrence! Thank you so much!
- Mac Mini 6.2, (2014), internal SSD+HD, 2,3 GHz Core i7 quad, 16 GB RAM, MacOS 10.14.6 Mojave with Presonus Firestudio Tube, Firestudio Project with Universal Control 1.7.6,
Presonus Faderport 8, Atom, Bluetube DP, HP 4, Bluemax..... - iMac 27" 3,4 GHz Core i5 quad, 1TB Fusion-Drive, 40 GB RAM, MacOS 10.15.7 Catalina with Presonus Studio26C - MacMini M1, 16 GB RAM, 1TB SSD Big Sur 11.2.2 External harddiscs (3.5" - 7200 rpm) USB 3.0 Presonus Studio One Pro 5.1.2 Celemony Melodyne Studio 5.1.1 Softube Console1 MK II (Console1 Version 2.5.9) |
MarkusHassold wroteHow could I miss this for half a year? Same here! Thanks so much Lawrence!
George Ware
StudioOne v5.1.2 Pro 64bit Waves SoundGrid Studio 2 Waves DigiGrid IOS Waves DigiGrid IOX Waves SoundGrid Server One PreSonus CS18ai & BCR2000 Control Surface Intel 6 Core i7 3.2Ghz. Windows 10 Professional 64bit. v20H2 Arturia KeyLab-88 Essential URS, Waves v12 (Everything), EMI, Sonnox Oxford (Everything), Antares Unlimited, Plugin Alliance (Everything), Nomad Factory,TL Labs, Massey, Komplete Ultimate 12 CE, Arturia V9 (Everything), Korg Collection, UVI Falcon v2, Melodyne Studio 4.4.2, VocAlign, Eventide (Everything), Softube and IKM Total Studio Max. As of 4 Feb 21 |
Hi
How do i make my own set of color to import into the script? I saw an TXT example file, tried to import it , but ![]() I then exported the default color set to see it's content, but i rally don t understand the color code inside that file. -10079488 -6730752 -32768 -19866 ........ ........ I can clearly see they are 40 color codes , but can t understand each of them. IMPORT HEX COLOR : how to do this? what is the type of the data to be imported? A css file or what? A complete HOW TO will be great! Thanks |
They cover this pretty well on page 2 of the thread. User Trucky posted some sights which explain the color numbers pretty well too, especially this one: https://www.rapidtables.com/web/color/RGB_Color.html
Mike Derrick | Studio One Professional 5, Win10 Pro 64, AMD Ryzen 3, 32GB RAM, SSDs, Focusrite 2i4 BandCamp SoundCloud |
Is there a way to colorize the Mixer channels without adding them to the arrange window?
for example Single outs of Impact ?
StudioOne, FaderPort Classic, FaderPort 16, Windows 10, Samsung C49RG94SSU (5120x1440),
I7-4770k, ASUS Gryphon z87, 32 GB RAM, Sapphire RX580 Nitro + , 8GB RAM, RME Multiface II __ macOS Mojave Apple iMac 27-Inch "Core i7" 3.5 (Late 2013) , (yes it supports Metal) https://ansolas.de |
Users browsing this forum: No registered users and 50 guests
