Studio One 4 not sending Midi data (even though it says it does)
Posted: Mon Mar 18, 2019 10:21 pm
So, recently Studio One stopped sending MIDI data to my external gear.
Setup
I have:
- the original Faderport
- a Behringer XTouch mini
- a Behringer Model D
- an Arturia Minibrute
All connected through USB, and none of them are receiving any data.
Studio One 4.1.3 running on Windows 10 (64 bits)
Symptoms
Studio One does receive data properly. I also have a USB keyboard controller (M-audio Keystation 61), and Studio One receives the data properly. It also receives data from the Faderport and the XTouch Mini (the other devices don't send Midi, they just receive it)
All the devices are configured properly and marked as active. When I look at the MIDI monitor in Studio One, it tells me that the data is sent. However none of the devices is actually treceiving it.
So, for example, if I move the fader on the Faderport, the fader for the selected track in Studio One moves. But if I move the fader in Studio One, it doesn't move on the Faderport.
Same for the XTouch Mini, it can send to Studio One, but is not receiving anything.
Or if I send MIDI notes to the Minibrute or the Model D, the MIDI monitor shows the note on/note off events, but nothing is received by either device.
Some debugging I've tried
In order to debug the issue I've done the following:
- I've unplugged each device and plugged in one by one - with no success
- I've tried to click the "reconnect" button in Studio One. When I do so I've noticed that each device receives a single event (the fader moves one time on the Faderport, for example).
- To make sure it is not an issue with my USB ports I've run Cubase 8, and everything works fine there - the devices do receive MIDI data.
So, I'm pretty stucked there. I know it's not a hardware issue, since everything works fine in Cubase, but everything else works like a charm in Studio One so I have no idea what to do next.
Any help would be greatly appreciated.
Hubert.
Setup
I have:
Symptoms
Hubert.
