Editing MIDI - How can I move MIDI controller data when I move the MIDI notes?
Posted: Tue Feb 12, 2019 11:23 pm
I'm currently editing a solo piano piece and I'm working on nudging notes to just the right spot, but it's getting to be a little frustrating to also then have to move the sustain pedal off/on controller messages separately. Especially since I can't figure out how to select them to move them. I can click and drag each point on the line, but this would go so much smoother if the controller data moved along with the notes. Is there a way to do that?
EDIT: For bonus points, is there a way to do ripple editing in MIDI? I'm trying to get the timing right in some spots, but I can't just move certain notes. I have to select every note in the track from that point to the end and slide them all together. That's a little annoying because when I'm zoomed in, I have to zoom all the way out to see the entire song, select the notes, then zoom back in to do the move. Is there an easier way to do that? There must be, but I'm still learning S1.
