Page 1 of 3
Microphone Setup
Posted: Mon Feb 11, 2019 11:12 pm
by BANANADRAMA
I am presuming most of you use microphones for recording (dare I say all of you?), so I would value your expertise in guiding me along here.
Before I go into it, let me just emphasise this: if you want to write ''just Google it'', don't. I have Googled it, but as always, the problem and solution for person X with mic Y are usually very different to the problem and solution of person A with mic Z; it's usually not applicable. Besides, I like my solutions in real time, not from 7 years ago.
Anyway. I have a stand up mic Audio Spectrum OSM-800; if that matters. I have plugged the cable into my Audiobox (that silly sausage of a discontinued product), but uh....no message came up to set it up or let me know a device has been added. Should I add it in my Control Settings first, somehow? Or in SO? How? How do you do it? Shouldn't be that different for me, and I am wasting my time perusing articles on it, only to find it's only for Mac users or something. How do I get the computer/SO to recognise my mic? I am watching some videos, but it appears these chaps alreday have their mics set up.....
Any advice on how to get this to work would be much appreciate, but again: if you have nothing else to say but ''why don't you Google it'', don't. If it's not obvious to you that people usually ask for help after Googling hadn't offered a solution, well.....now you know what the last resort of the technologically challenged is. All I want is for the world to hear me roar.....and I need my mic for that, man; I need my mic for that
Re: MICROPHONE SETUP
Posted: Mon Feb 11, 2019 11:34 pm
by matthewgorman
Some people like Bing.
Make it simple for yourself. When you open Studio One and start a new song, use the template for your interface in the devices tab. All the input and output routing is done. Create a new audio track, and use mono input one (not L or R).
Plug your mic into input 1, and turn on the 48v button. Rais the input gain until you have a good signal showing on the S1 meters. Press record in the transport to start recording, assuming that the track itself has been armed to record. Start there, and when you have that we cn get you the rest of the way.
Posted: Tue Feb 12, 2019 1:37 am
by andreasvenzke
Hello!
Your mic is a condenser mic! So you have to switch on phantom power on the front of your audiobox.
As Matthew said, you than have to choose the right input in Studio one. A mic is no digital device that is automatically recognized by a computer. (only Special USB-mics work this way)
greetings from Germany
Andreas
Posted: Tue Feb 12, 2019 7:15 pm
by BANANADRAMA
@matthew: Those who prefer Bing are squares. Everybody knows the hip choose Frankie
@andreas: Thanks. I have no idea where to do that, but I'll add to my existing headaches by Googling it. Sorry, matthew. Binging it. I wouldn't want to offend any squares!
Posted: Tue Feb 12, 2019 7:50 pm
by bartbalint
Phantom power is just another term for +48volt that the mic needs. I don’t know which Audiobox you have (couldn’t really find any that looked like sausages ), but the 48 volt button is usually right on the front of the interface.
Cheers
Re: Microphone Setup
Posted: Wed Feb 13, 2019 4:20 am
by BANANADRAMA
Found the 48V button, so that's great. But when I try to arm for recording (pressing R. Told yu I watched all the vids), nothing records. It gives me a message ''failed to activate internal microphone'' or something.
Also, tried to choose mono. Still nothing. 48V is on. Mono chosen. Gives me that message (says recording/playback devices don't match, but I think they match just fine). Nothing happens.
Posted: Wed Feb 13, 2019 5:43 am
by Jemusic
Is your Audio Box interface properly installed and configured in the IN/OUT settings. In Preferences/Options go to Audio Setup. Up the top the recording and playback device needs to be selected there as your AudioBox interface.
Click on the Song Setup down bottom left. Your Input and Output configuration needs to be setup.
Once you have done all that when you create an audio track you will see Audiobox inputs available as the input source. Select the required input. For a mono track it will be Input 1. (left)
Posted: Wed Feb 13, 2019 10:41 am
by BANANADRAMA
Jemusic wroteIs your Audio Box interface properly installed and configured in the IN/OUT settings. In Preferences/Options go to Audio Setup. Up the top the recording and playback device needs to be selected there as your AudioBox interface.
f
See here is the crux of my woes. The audio set up. Sigh. Where should I begin?
If I choose Audiobox as default audio device, the sound stops working both in S1 and on my computer, I can't have that. If I choose Windows audio as default in SO, the sound works perfectly, but then I can't use the mic through my audiobox. I have a ticket open just for that, but if any of you have any idea why Audiobox is such a ****, please, offer your theories and possible solutions to me.
Posted: Wed Feb 13, 2019 12:40 pm
by Neiby
Posted: Wed Feb 13, 2019 4:09 pm
by BANANADRAMA
I don't think you understand. My audio ONLY and exclusively works with Windows Audio. If I choose Audiobox, the audio STOPS WORKING for me on Windows AND S1. I was aksing if anyone knew why, but apparently everything works perfectly for everybody else, since nobody has has this problem. I have had this problem on my former computer, and now here. i am doing something wrong, but don't know what.
I know how to set up the damn device; if I do, bye bye all audio. I thought I had made that clear.
Posted: Wed Feb 13, 2019 4:28 pm
by Neiby
I'm just trying to help. It's not immediately clear to me why setting up your audio device in S1 would stop your Windows sounds. I don't know what you already know, and I don't know what you've already tried.
It's not that everything works perfectly for everyone. DAW audio has all sorts of gotchas that seem to change from system to system, since no two systems are identical. Every time I get a new audio interface, I run into some new problem to solve.
I don't have that interface, but I had the AudioBox iTwo, which is similar. The only suggestions I have:
* Make sure you have the latest version of Universal Control installed
* Make sure the audio interface has the latest firmware
* On the interface itself, make sure the main level is turned up and that the mix knob is turned all the way to Playback (I know this is all obvious and you've surely already done it, especially since it sounds like your computer is already using that interface is its default output device.)
Here is a forum post from elsewhere where someone has what seems to be a very similar problem. Unfortunately, this particular thread doesn't have a resolution, but perhaps it will help somehow.
https://makemusic.zendesk.com/hc/en-us/ ... diobox-usb
Posted: Wed Feb 13, 2019 4:32 pm
by Neiby
Also, one thing that might help is to look for an option called something like "Release audio device in background" and check it.
https://answers.presonus.com/15176/plug ... h-speakers
Posted: Wed Feb 13, 2019 4:41 pm
by BANANADRAMA
I am not snapping at you; I am feeling chippy about the fact that I had spent ALL my savings on Presonus gear and it refuses to work. I am not the only one, thank heavens, so the problem must not be in my well-admitted technical debility.
This is my experience, word to word. It's good that it works for you all, but I believe if I spend so much money on something, it had better work for me, and it doesn't. As it is, I have wasted two years already on trying to get things to work in SO, because if one thing works, another one stops. If I had any more money, I would just warn other potential buyers on Amazon about this and give a chance to another DAW that might actually care for their customers, but I haven't any more money, so I am stuck with this mess. Tech support is of no help whatsoever, and I am beginning to believe I am talking to bots because the answers go in a loop, and I am wasting my time not being able to record because of this junk interface (that has been discontinued, surprise, surprise; after so many complaints from users).
Thanks for the link; I am willing to try anything now, but I am afraid I will have to purchase another interface, and I can't afford that, so it seems to be another year is going to waste because of this Idiotbox interface junk.
Posted: Wed Feb 13, 2019 4:44 pm
by BANANADRAMA
Neiby wroteAlso, one thing that might help is to look for an option called something like "Release audio device in background" and check it.
Thanks, but I have already tried that and everything else. Still doesn't work. I really have Googled everything before asking for help here.
It keeps giving me the messages that
a) it has failed to launch internal microphone (what)
b) my sample rates don't match (huh)
At the moment; if I fix this, I am sure new ''XYZ has failed to initialise'' messages will appear.
Posted: Wed Feb 13, 2019 4:46 pm
by Jemusic
What is the exact model of the interface please. In your OP you mentioned it is discontinued. So is it old. Maybe Studio One won't work with it anymore (although unlikely)
Posted: Wed Feb 13, 2019 4:51 pm
by BANANADRAMA
Audiobox USB 96 ''JUNK MODEL'' (the 'junk' part is my extra, excuse moi). It certainly should work. SO recognises it, but if I choose it as default, my audio on SO and my PC stops. It only works if I have Windows Audio, but then I can't use my microphone. Whatever happened to just strumming the guitar on a street corner.....I am an artist, not an engineer, and this is draining all my enthusiasm. I want to create, not fight with machines--or if I have to, I should at least get paid for being the newest incarnation of John Connor.
Posted: Wed Feb 13, 2019 4:55 pm
by Neiby
sarabalazic wroteNeiby wroteAlso, one thing that might help is to look for an option called something like "Release audio device in background" and check it.
I believe (but am not sure) that the reason you're getting that microphone message is because you have Windows audio set as your interface, and S1 doesn't know how to access your PC microphone.
How do you have your speakers connected right now? Is it PC -> Audiobox -> Speakers? Or are you speakers connected directly to the PC?
Posted: Wed Feb 13, 2019 5:13 pm
by BANANADRAMA
A speaker set, you mean? The kind of speakers I could plug into my interface would need a fancy USB, translated, it means I would have to spend spend spend on it again, and I am in debt already because of all the gear I'd bought. The speakers I've got are cheap, and have a USB I can't plug into interface, so PC it is.
I have the option to choose Audiobox as default. I click it, and it gives me one of the messages I had listed, and the sound stops to work. Both on SO and on PC. Also, there is a light where 'CLIP' is written that keeps turning off and on if I move the mic USB. No idea what that signifies. I can't push it the plug any deeper, but if I so much as blow a kitten's breath into it, it falls out of the plug.unit. I got scammed somewhere, because I spent a bloody fortune on all this.
Posted: Wed Feb 13, 2019 5:19 pm
by BANANADRAMA
Btw, have any of you ever used Audiobox junk? Because from what I read, I can see why it was discontinued. Nothing but ''give me my money back, scammers'' complaints when I Googled it. I am really afraid I'll need to buy a better interface and starve through the month again. I should have SO Artist. It would be the artist (because it doesn't allow me to be), and I would be the starving. Strange madfellows
Posted: Wed Feb 13, 2019 6:32 pm
by bartbalint
sarabalazic wroteAudiobox USB 96 ''JUNK MODEL'' (the 'junk' part is my extra, excuse moi). It certainly should work. SO recognises it, but if I choose it as default, my audio on SO and my PC stops. It only works if I have Windows Audio, but then I can't use my microphone. Whatever happened to just strumming the guitar on a street corner.....I am an artist, not an engineer, and this is draining all my enthusiasm. I want to create, not fight with machines--or if I have to, I should at least get paid for being the newest incarnation of John Connor.
Sarabalazic,
I take it that you have your Audiobox connected to the PC with a USB cable, and that it shows up as a possible audio device. And your mic is connected to the front of the Audiobox with the 48v button pushed and lite up. But that you dont have any audio outputs on the back of the Audiobox connected to anything.
So to select the Audiobox as your device and hear what you record, you will need to connect your speakers to the outs on the back of the Audiobox. Or you could connect a pair of headphones to the headphone out on the back of the Audiobox.
If nothing is connected to the back of the Audiobox, then when it is selected as the audio device, you wont hear any Windows sounds, or any StudioOne sounds.
Not sure what type of connection your current speakers are, ( I assume 1/8th connector to the side of your computer, or you may just be using the speakers built into your laptop), but you can get an adapter to allow you to connect those (if they are separate speakers) to the back of the Audiobox. Then you should be able to hear both Windows and StudioOne when Audiobox is selected as the audio device.
Or you could get a cheap pair of headphones with a TRS 1/4 in connector to plug into the Headphone outs on the Audiobox.
This would be the same issue with any DAW and any Audio device. For example I am using a Focusrite Audio device for inputing my mic and then have some speakers plugged in to listen to both Windows sounds and StudioOne.
