I no longer need studio one 3 on my system as i am using studio one 4 pro now and was wondering how i can remove studio one 3 without losing any of the important parts
What is the process for removing studio one 3 correctly and leaving 4 intact and still having all the additional content remain
Thanks
Dan
Windows 10 64 bit (1809)
32GB of LPX vengeance RAM
I7700K cpu
Line 6 Helix Rack (Audio Interface)
Studio one 4 Pro 64bit :punk:
by snb1 on Mon Jan 21, 2019 10:30 am
danielbutler1 wroteI no longer need studio one 3 on my system as i am using studio one 4 pro now and was wondering how i can remove studio one 3 without losing any of the important parts
Thanks
Dan
Drag your Studio One 3 application from the application folder into the trash. Remember that just removing Studio One 3 from the dock into the trash does not remove the application of your computer.
Studio One Pro 4.5.4 64 bit, Mac OS 10.12.6, Mac mini (Late 2012) 2.3GHz quad-core Intel Core i7 (Turbo Boost up to 3.3GHz) with 6MB L3 cache, Intel HD Graphics 4000, 16 GB ram, 240 GB OWC Extreme Pro 6G Solid State SATS Drive startup disk, 1 TB internal SATA Dive, (2x) 1 TB External Glyph Studio 7200RPM eSATA Drives, 500 GB External WD Drive
by garyshepherd on Mon Jan 21, 2019 11:57 am
I think he means - what other Studio One 3 files can be removed as well as the app itself? I have the same situation and have not trashed 3 yet - and assume there must be some files relating to 3 that are also not needed. Any ideas - removing the app is the easy bit.
Gary Shepherd
____________
iMac 27" 3.3 GHz Intel Core i5, 32 GB Ram, Mojave OS 10.14.6, 64 bit, Studio One 4 Professional 4.6 (always the latest) , Reason 11, Melodyne 4.2.3 Editor, Digital Performer 10.01, Korg Legacy Wavestation and M1, Arturia minimoog V, Helix Native 1.82, Bias FX 2 Elite 2.1.6, Superior Drummer 3.1.2, EZkeys 1.2.5, Alesis Q49, Audient iD14, Faderport 2018, Gibson Les Paul Standard, James Tyler Variax JTV-59 and other gear.
by danielbutler1 on Mon Jan 21, 2019 12:05 pm
garyshepherd wroteI think he means - what other Studio One 3 files can be removed as well as the app itself? I have the same situation and have not trashed 3 yet - and assume there must be some files relating to 3 that are also not needed. Any ideas - removing the app is the easy bit.
Exactly , the advice above is useless to me, i am not even on a Mac which it clearly show in my Sig
I want to uninstall studio one 3 but am unsure if it will remove files i can use in Studio one 4 pro
Like loops for example or certain instruments etc etc
I7700K cpu
by Bbd on Mon Jan 21, 2019 4:28 pm
I would back up my system first.
You can install the most recent release of Studio One from your PreSonus account which will install all the items that come with it. You do not have to install over your older version - just give the install folder a new name. Then test to see if your older songs come up OK.
It is hard to know exactly what other items with your older install you needed in your specific case.
So best bet is to contact Support if you are unsure.
Bbd
by Tacman7 on Mon Jan 21, 2019 8:27 pm
I've never tried removing one. To save space?
I just let them languish there until I build a new computer.
You might have read my book, "Lazy mans guide to Studio One"
Melodyne Studio - Nectar Impact LX25+
by snb1 on Tue Jan 22, 2019 1:41 pm
Oops lol. That's my fault. I'll double check the signature next time.
by roland1 on Tue Jan 22, 2019 1:47 pm
In Win. the main Studio One folder in "documents" needs to be preserved, always. It also seems to be updated when a new version is installed (for instance, the older templates get a separate sub folder after installing.)
The roaming folder should be checked. Not sure what's in there.
Also, the program folder - I think the prefs here get updated as well, but you will find a v3 folder that may have something you need - device settings, etc.
That's all I can think of for now.
I think you can then delete S1 v3 ("remove application"or whatever that Win feature is called) because it "shouldn't" removed any of the vital folders that are still related to v4. That said, who knows. I'd suggest to backup everything. Twice. That's how I sleep at night. :)
I use: Studio One Pro v4.53 on i7 7700 win10 PC w16GB RAM and Mac Pro Tower (Sierra) w/RME & Focusrite interfaces.
Attention all shoppers: The people in commercials are paid actors pretending to like the product. It's easy to forget that fact with the music blaring and their happy smiles flashing.
by darrenporter1 on Tue Jan 22, 2019 5:46 pm
Yeah I second the notion... best not to uninstall it at all. Disk space is the cheapest upgrade you can make.
Studio One Professional 4.6.1
UAD-2 PCIe DUO (two of them), v9.11
Users browsing this forum: gregorbeyerle1, IanM5 and 20 guests
