Hi everyone!
I just bought a UVI Workstation but spent hours to add it on my DAW. I reset blacklist, reset VSTplugin folder, re-installed UVI (btw it works on its own correctly). Nothings changed. I can't see the UVI on the list in Studio One. I am fairly new in this industy so i am wondering if i am missing something too obvious?
I don't even want to think that UVI Workstation is not usable with Studio One! If that so i'm gonna die right now cause i spent almost 6 hours to make it work.
Thank you.
Computer: Windows 7 - i7 Q740 1.73Ghz 8GB RAM Tablet: The iPad (2017)
Mic: MXL 990
Interface: Presonus Audiobox iTwo
Midi: Arturia Minilab Guitars: Fender Deluxe 72 Telecaster, Gretsch G5420, Seagull Artist Studio CW Deluxe QII
Software: Studio One Artist 4, Ableton Live Lite, UVI Workstation, Analog Lab 3
Aim: Basically a singer&songwriter. Guitarist as a proffession. Recording ideas, covers, samples. Trying to do more.
by WaterlooSunset on Sun Jan 20, 2019 12:27 pm
1) Add you specs in your sig please :-)
2) You need the VST addon, purchased separately. Did you get this?
https://answers.presonus.com/29541/studio-artist-require-rewire-support-for-third-party-plugins
Win 8.1, MSI G41 Z87, I4770K (no OC), 16GB, NVIDIA 710, 2x27" Monitors 480Gb SSD, 2x1TB WD Blacks. SYBA Firewire SD-PEX30009, FS Mobile. Monitor2USB, S1 Pro 4.1.1
Hobbiest - Mainly Guitars, UVI, Soundtoys, NI, IK, EZ2, SD3, BFD Eco GR5, TH3, Amplitube 4, Waves GR,
Korg 707, NanoPAD2, MicroKey2. Eris 5, B2031A
by riniehuigen on Mon Jan 21, 2019 12:06 am
Since you reset the blacklist I presume you own the vst addon. Please make sure that the correct pad is added to the scanned folders. Could be your vst is not in one of the default locations.
Computer: Windows 10, i5 2500K, 8Gb mem, Steinberg UR242, Line 6 UX1, Studio One Artist 4 & Cubase Artist 9.5. Guitars: Blade RH4, Takamine GN51CE. Microphones: AKG C3000, Rode NT1A, Rode M3.
Band: http://www.idrismuziek.nl
by riniehuigen on Mon Jan 21, 2019 2:48 am
The following link might be interesting. You could try the solution at the bottom.
https://support.uvi.net/hc/en-us/articl ... -in-my-DAW
Windows users: this may be the result of a VST cache issue. Create a sub-folder in your VST location, move the UVI Workstation plug-in DLL file there, then rescan your VST locations in Live preferences. After this you can move the DLL file back to its original location and rescan your VST locations if you’d like.
Hope this helps...
by kutaykokar on Mon Jan 21, 2019 12:41 pm
Thank you guys for your answers.
@WaterlooSunset is right. I didn't know that i was needed the add-on. I'm a little disappointed though since i really liked Studio One Artist as it is very user friendly and easy to work with but is trash without that VST-AU add-on. I think i will use my UVI with Ableton and continue working with Studio One with the recorded file for a while.
Mic: MXL 990
