Recording Audio
Posted: Sun Jan 20, 2019 5:37 am
by timconway1
New user question here.
When I'm making an overdub recording on an audio track, how can I hear the previously recorded audio on that track
Re: Recording Audio
Posted: Sun Jan 20, 2019 5:57 am
by garyshepherd
Are you dropping in to that track? Punch in should allow that. Otherwise just record on another track while listening to the first one - then edit together.
Re: Recording Audio
Posted: Sun Jan 20, 2019 7:01 am
by timconway1
Thanks but I'm recording a vocal track a phrase at a time and I want to get the cue from the previous phrase. I don't want to have to set up a new punch in point every time I do this. Sounds like that would be very time consuming. For the same reasons I don't want to create a new track every time I record the next prase.
Hmmm, I didn't realise this limitation in S1's recording method. I need a work around
Re: Recording Audio
Posted: Sun Jan 20, 2019 8:10 am
by gwp9999
I'm not sure what you are trying to do.
Why not describe how you would like S1 to act for what you are trying to do and what DAW you use to do this now.
Re: Recording Audio
Posted: Sun Jan 20, 2019 8:27 am
by timconway1
gwp9999 wroteI'm not sure what you are trying to do.
I'm recording a vocal track a phrase at a time. When I come to record the next phrase I want to pick up the cue (i.e. when to start singing) from the previous phrase. The problem is that as soon as you hit Record you don't hear any audio that was previously recorded on the track.
I've migrated from Sonar where this wasn't a problem. You could overdub record on a track and still hear what had been previously recorded.
Re: Recording Audio
Posted: Sun Jan 20, 2019 8:51 am
by garyshepherd
Because I am not a technically great singer I do sometimes do a phrase or line at a time. The separate track method works perfectly for me - but you say you don't want to do it that way. Not sure why, but its your choice - you maybe have 2 or 3 tracks and just switch between them - you don't need a separate track for every phrase as that would be untenable!
Re: Recording Audio
Posted: Sun Jan 20, 2019 8:53 am
by Tacman7
I work with punch in on all the time.
So S1 will only record between the loop markers with punch in on.
If you work in arranger sections it's really easy to set the loop markers by clicking on a section or event and hit the 'P' key.
So you would hear what you've recorded then start singing the next part right when record kicks in.
Works great for me.
Re: Recording Audio
Posted: Sun Jan 20, 2019 9:31 am
by timconway1
garyshepherd wrote Not sure why,
To me it just doesn't seem like a very elegant or efficient process/method
garyshepherd wrote you maybe have 2 or 3 tracks and just switch between them - you don't need a separate track for every phrase
Yep, at the moment this would seem the best way around it
Tacman7 wroteIf you work in arranger sections it's really easy to set the loop markers by clicking on a section or event and hit the 'P' key.
Not sure I understand what you mean by "arranger sections" but I'll experiment with Punch. It still sounds a bit of a faff resetting loop markers every time I move onto a new phrase though.
Now if I was a better singer then problem solved
Re: Recording Audio
Posted: Sun Jan 20, 2019 10:21 am
by edramsey
Hi. Have you played with the metronome pre-roll? I'm working on other things right now and not at my DAW, but if I am remembering correctly you can put your cursor where you want to start recording (at the end of your current track), arm your track, set the metronome to one or two bars of pre-roll and press start. Would that do what you want?
You also might want to consider opening the arranger track and setting up your arrange markers as you go. They give you some added capabilities during the arranging/editing phase.
Good luck with this.
Blessings.
-Ed
Re: Recording Audio
Posted: Sun Jan 20, 2019 2:09 pm
by garyshepherd
timconway1 wroteTo me it just doesn't seem like a very elegant or efficient process/method
timconway1 wroteYep, at the moment this would seem the best way around it
Not sure what process other than punch in and out that would handle what you want - and I wouldn't want to work that way anyway when it is so easy to set up new tracks - and then edit afterwards (audio editing is also a breeze). Personally I find 2 or 3 tracks which I switch between is certainly efficient and works well , including with editing the audio after recording. Elegance I am not worried about ! You should find that the workflow in S1 is really good - you may need to find slightly different methods than other DAW's.
Re: Recording Audio
Posted: Sun Jan 20, 2019 3:26 pm
by darrenporter1
I would be shocked if there wasn't a video on YouTube comparing all of the ways you can do punch-ins in S1. For this feature you could even watch one that was made for version 2 I would imagine.
Re: Recording Audio
Posted: Mon Jan 21, 2019 5:39 pm
by michaelrendall1
Preferences, advanced, console, audio track monitoring mutes playback
