Toggle tracks - How can I do this?
Posted: Fri Jan 18, 2019 5:22 am
by timconway1
Apologies if I’m not making this clear but is there a way (enabled with either a single mouse click or a single key press) to toggle between two tracks playing soloed?
To put it another way - I Have a song with say, seven tracks in total. I'm hearing one track on its own but then I want to switch instantly so I'm hearing another track on its own.
Re: Toggle tracks - How can I do this?
Posted: Fri Jan 18, 2019 5:25 am
by niles
Hold ALT when soloing.
Posted: Fri Jan 18, 2019 5:30 am
by timconway1
Okay thanks.
Does that mute all the other tracks irrespective of whether or not they're already soloed?
Posted: Fri Jan 18, 2019 6:05 am
by Nip
as I recall it does with exception of those solo saved.
There are two other solo mouse click combinations
shift solo - solo save, meaning include these always when soloing, like for effect send tracks etc.
ctrl solo - global solo, toggle all solo on/off
Select a number of tracks, and solo - soloes all those etc.
Posted: Fri Jan 18, 2019 8:24 am
by timconway1
Thanks for those tips,
In my old DAW (Sonar) you could mute selected audio events by hitting the K key
Is there any equivalent in S1?
Posted: Fri Jan 18, 2019 8:41 am
by Nip
timconway1 wroteThanks for those tips,
I think I had Q key to do that in Sonar, but probably configurable.
There are key commands connected in S1 as well, check out the config dialog and look around.
https://s1manual.presonus.com/Content/F ... %20commandAlso check out macro toolbar in S1 to do very powerful stuff.
https://s1manual.presonus.com/Content/E ... %20commandI got a tip - Ctrl mouse wheel - to change size of fonts in help system.
Posted: Fri Jan 18, 2019 8:43 am
by tomscheutzlich
Toggle mute selected part: Shift+M
Posted: Fri Jan 18, 2019 9:35 am
by timconway1
Cheers fellas
Posted: Fri Jan 18, 2019 10:35 am
by jmorrisondgd
If I'm not misunderstanding what your looking for, "solo follows selection" is a more straight forward way.
Posted: Mon May 22, 2023 7:18 pm
by carlstrazzulla
niles wroteHold ALT when soloing.
I had this same question today and this solution worked. Nice & simple. I am busy recording acoustic guitar using a number of different settings & I want to be able to switch quickly between tracks.
thanks much.
