Apologies if I’m not making this clear but is there a way (enabled with either a single mouse click or a single key press) to toggle between two tracks playing soloed?
To put it another way - I Have a song with say, seven tracks in total. I'm hearing one track on its own but then I want to switch instantly so I'm hearing another track on its own.
Studio One Pro 4.1, Windows 10 x64, Intel i5 3.40GHz, 8Gb RAM
Focusrite Scarlett 18i20
by niles on Fri Jan 18, 2019 5:25 am
Hold ALT when soloing.
OS: Windows 7 Pro x64 | HW: P9X79 • i7 3930K • 16GB • HD6450 (WQHD) • RME AIO
by timconway1 on Fri Jan 18, 2019 5:30 am
Okay thanks.
Does that mute all the other tracks irrespective of whether or not they're already soloed?
by Nip on Fri Jan 18, 2019 6:05 am
as I recall it does with exception of those solo saved.
There are two other solo mouse click combinations
shift solo - solo save, meaning include these always when soloing, like for effect send tracks etc.
ctrl solo - global solo, toggle all solo on/off
Select a number of tracks, and solo - soloes all those etc.
by timconway1 on Fri Jan 18, 2019 8:24 am
Thanks for those tips,
In my old DAW (Sonar) you could mute selected audio events by hitting the K key
Is there any equivalent in S1?
by Nip on Fri Jan 18, 2019 8:41 am
timconway1 wroteThanks for those tips,
I think I had Q key to do that in Sonar, but probably configurable.
There are key commands connected in S1 as well, check out the config dialog and look around.
https://s1manual.presonus.com/Content/F ... %20command
Also check out macro toolbar in S1 to do very powerful stuff.
https://s1manual.presonus.com/Content/E ... %20command
I got a tip - Ctrl mouse wheel - to change size of fonts in help system.
by tomscheutzlich on Fri Jan 18, 2019 8:43 am
Toggle mute selected part: Shift+M
Tom Scheutzlich
QA Lead, PreSonus Software Ltd, Hamburg, Germany
MacBook Pro (Retina, 15-inch, Late 2013) / Apple 27" thunderbolt display (2560 x 1440) / macOS 10.14.3 / Faderport 16 / PS-49 Keyboard / ... / Hamburg Plug-in and Audio Interface Museum
by timconway1 on Fri Jan 18, 2019 9:35 am
Cheers fellas
by jmorrisondgd on Fri Jan 18, 2019 10:35 am
If I'm not misunderstanding what your looking for, "solo follows selection" is a more straight forward way.
Users browsing this forum: wallygontowski and 24 guests
