So I updated to V4.1.2 and was working with some audio last night to tighten some timing up. I split an event into a smaller chunk and bounced. Then enabled Audio Bend and created bend markers. All good. I could move the markers, bend audio etc. However, when I manually added a bend marker then moving any bend marker would move the audio all the way down the event, not respecting other bend markers.
I did this on several tracks and had the same issue. Audio Bend would only correctly work if I didn't add any manual markers.
Anybody try this or see the same thing?
Studio One v5.5, Windows 11 x64, AMD , 32GB Ram, AMD Radeon Video, Behringer X32 Producer USB interface, Line6 Helix floor, Line6 GearBox Gold
by snb1 on Fri Jan 18, 2019 9:01 am
reginaldStjohn wroteSo I updated to V4.1.2 and was working with some audio last night to tighten some timing up. I split an event into a smaller chunk and bounced. Then enabled Audio Bend and created bend markers. All good. I could move the markers, bend audio etc. However, when I manually added a bend marker then moving any bend marker would move the audio all the way down the event, not respecting other bend markers.
Is this what you are experiencing?
Studio One Pro 6.6 64 bit, macOS Monterey 12.6, 14" MacBook Pro M1 (2021),16gb ram, 512 SSD, 8-core CPU
SkipNo Beet
by stefanrauch1 on Fri Jan 18, 2019 9:15 am
confirmed here.. something is off
OS: Win10 x64 || Software: Studio One Pro [latest version]
Hardware: AMD Ryzen 9 3950X || Asus Prime X570-PRO || 64GB DDR4 RAM || Asus Dual-RTX2070S-A8G-EVO || UAD2 Octo & Duo PCIe
Peripherals: RME Fireface UFX II (+2x ADA8200) || Faderport Legacy || Atom || NI Komplete Kontrol A25
Audio Settings: 44,1/48kHz, 256 Samples, DP Off, 64 Bit
by Janko Kezar on Fri Jan 18, 2019 9:49 am
Confirmed. I get the same behaviour.
Hopefully this one gets fixed soon
HP z230 i7/16gb , HP Elitebook 8470 i7/12gb ,Win 10, 64 bit, S1 3.3.1, 2.6.5 64bit Focusrite Saffire Pro 40, AllenHeath Qu-24, Steinberg UR22-mkII
by reginaldStjohn on Fri Jan 18, 2019 2:26 pm
Nice to see that it was just me loosing my mind. Thanks
Users browsing this forum: No registered users and 63 guests
