So I updated to V4.1.2 and was working with some audio last night to tighten some timing up. I split an event into a smaller chunk and bounced. Then enabled Audio Bend and created bend markers. All good. I could move the markers, bend audio etc. However, when I manually added a bend marker then moving any bend marker would move the audio all the way down the event, not respecting other bend markers.
I did this on several tracks and had the same issue. Audio Bend would only correctly work if I didn't add any manual markers. Anybody try this or see the same thing? |
reginaldStjohn wroteSo I updated to V4.1.2 and was working with some audio last night to tighten some timing up. I split an event into a smaller chunk and bounced. Then enabled Audio Bend and created bend markers. All good. I could move the markers, bend audio etc. However, when I manually added a bend marker then moving any bend marker would move the audio all the way down the event, not respecting other bend markers. Is this what you are experiencing?
Studio One Pro 4.5.4 64 bit, Mac OS 10.12.6, Mac mini (Late 2012) 2.3GHz quad-core Intel Core i7 (Turbo Boost up to 3.3GHz) with 6MB L3 cache, Intel HD Graphics 4000, 16 GB ram, 240 GB OWC Extreme Pro 6G Solid State SATS Drive startup disk, 1 TB internal SATA Dive, (2x) 1 TB External Glyph Studio 7200RPM eSATA Drives, 500 GB External WD Drive
Users browsing this forum: darrenporter1 and 23 guests
