1 post
Dear Studio One Users,
the first update in 2019, Studio One 4.1.2 is ready for downloading. We wish you a creative new year with the new functions, fixes and improvements.
Enjoy!
Ari
______________________________________________
Version 4.1.2 Release Notes (January 15, 2019):
New features and Improvements:
• AAF export now compatible with Digital Performer 9 (legacy mode)
• AAF volume automation support for Pro Tools
• Alternative incremental workflow for Song Versions
• Quantize Macros now work without forced Auto-Quantize
• Safety query for resetting recent song list
• Tempo Warp in arrangement now updates the editor display
• Better error handling in case of product activation failure
The following issues have been fixed:
Groove Quantize always affects velocity
• Sustain parameter is continuous for stock instruments
• Drawing Automation backwards doesn't work correctly
• Tempo ramp causes audio artifacts
• [AAF] Event gain not translating into Pro Tools clip gain
• Wrong English translation "Quintole" and "Septole"
• [Impact XT] Clear Bank and Pad do not clear parameters
• In certain cases, Melodyne won't sync to Song tempo
• [Tempo Track] 'Delete Range' inserts unwanted Time Signature change
• Relative movement of two adjacent notes no longer possible
• Inconsistency when using “Select Notes…> Select at interval” command
• Notes played in precount/preroll have incorrect length when recorded
• Timestretching kills transients when Tempo Track is used
• Notes recorded before active loop are shifted to left locator
• Redraw error in Pattern Editor controller lanes
• IR Maker help page text not legible
• [macOS] Remove "Release audio device in background" option (Windows-only feature)
• [macOS] Some keyboard shortcuts ignored when editing text in Track or Channel Name field
• [macOS] Holding cmd+w opens multiple dialogues, crashes on confirmation
• Splice license conflict w/ previous Artist activation on same account
• Crash on hitting "Return" key when assigned to Navigation > Enter
• Waveform graphics rendered with half-sample offset on bounce
• Track notes don't persist through transform operations
• “Delete external device” dialog lacks confirmation
• Mouse scrolling doesn't work on mixer inserts
• Crash when switching editor from melodic mode to drum mode at small window sizes
• Right-click mouse state not reset when loading a song version from recent list
• Freeze on zooming beat-linear audio parts in and out repeatedly
• Switching to another Song Version can break the Project < > Song connection
• When the editor is detached, deletion of selected notes will delete containing part
• [Scratch Pad] note length value jumps to unexpected value while modifying in Inspector
• Wrong Track order when duplicating Track with mouse
• Crash when opening "Tracks" node in file browser on certain songs
• MIDI Markers not embedded into MIDI files (when using “Save As”)
• Warp Marker editing causes glitches
• Exchange update button hard to read in light mode
• Unwanted scrolling in arrangement when editing Event in Folder Track
• Crash on 'Select from event till end'
• Crash when removing Splitter from fx chain
• Ripple Edit in Folder causes Track to shift
• “Split At Grid” broken when Event is located at a specific position
• [Project Page] Album / Artist text fields lacking contrast on edit when light theme is used
1 post
Users browsing this forum: BezowinZ and 30 guests
