So, I'm trying to map out a template that uses ST3.7 exclusively. There's some instruments I want to group together, like all the keys I want to send ST3.7 OUT 3-4, Guitars to OUT 5-6, Horns to 7-8, etc. However, in my screenshot if you'll note in the Console view far left, right under the Channels I want Channels 2-4 going to ST3.7 OUT 3-4. How do I make that happen? There's other grouping as well, but I know I can just copy those from the first. PLS NOTE MY JPG ATTACHMENT.
Tnx,
GPL :oops:
Note in the middle Left Console view right under the Track names where it lists the Channel & Groups.
Alesis Fusion 8HD kybd, PreSonus 1818VSL, PreSonus FaderPort8, JBL LSR 308 monitors. ASUS M5A97 EVO Mobo, 16Gig RAM, AMD FX-6200 CPU 3.8 Mhz, AMD Radeon HD 6670 Display. Win10 Pro 64Bit
by BobF on Wed Jan 02, 2019 3:17 pm
Can you make the image larger?
Studio One Latest Rel. / Notion 6 x64
Win10Pro x64 (1803) i7-6700 @3.8Ghz / 32G / 43" 4K | TASCAM US-16x08 / Event PS8 | FA06 / FaderPort 1 / LX61+
Waves Gold / Nomad IS3 / IKM Max / K11U
by georgelea on Wed Jan 02, 2019 3:25 pm
Sorry I tried to make it 2X's larger originally but the forum specs said the maxim size was 800X600. Bummer. :x :cry: :shock:
by BobF on Wed Jan 02, 2019 3:29 pm
You can provide larger images by using a hosting site, then a link to it here.
I like postimages.org, (FREE) but there are a number of them out there to choose from.
by Tacman7 on Wed Jan 02, 2019 3:48 pm
You set that up on the plugin, you have to activate the outputs just to the left of center at the top is a drop down that shows the outputs.
Then you assign them in the plugin where it shows the outputs for all the instruments.
Melodyne Studio
Where 'IS' Shitcreek? and
by georgelea on Wed Jan 02, 2019 5:18 pm
Tacman7,
Mucho appreciado, I thought you were mistaken, but after relentless attempts to prove it, you won! :+1
Now after fooling around, I accidentally made all the faders move simultaneously with Track 1. I don't know what I did. Trk 4 only has Volume under the M/S/Auto Off, and "Out 1-2, then a fader under that.
by Tacman7 on Wed Jan 02, 2019 5:25 pm
I make separate tracks for each instrument with progressive midi channels.
Track 1 channel 1, track 2 channel 2 etc.
Halion 3 works fine but the track sliders move together on one of my samplers. But they move separately in the console.
Never did figure out why that is. I just control them from the console.
Melodyne Studio
Users browsing this forum: markrobotham, ricstudioc and 18 guests
