Hello Presonus,
I have been a loyal (except for a few lapses) customer of S1 for many years and have enjoyed seeing the immense progress you've made. However, one area that I feel you lag behind in compared to other DAWs is user interface. Version 3 was a step in the right direction as was version 4, however, there is more room to improve - for me, specifically the way you render clips on the arrange page.
Here is an example of how Pro Tools renders MIDI and audio clips vs. how S1 does. Some simple things that make PT's UI superior IMHO:
- Each clip has a thin black outline
- The waveform colors are based on the clip color
- MIDI notes have some height to them and don't compete with CC automation lines
- The clips are translucent but have more opacity than S1. I've adjust the last row of clips slightly to show what this might look like.
- The waveforms are higher resolution and look smoother overall
- Clip title text is more legible
- Much broader range of clip color options
I hope you will take some of these under consideration for a future update.
Thank you!
by Lokeyfly on Mon Dec 17, 2018 3:16 am
Hmmm. A few UI things could certainly be refined, but I'm not seeing them in your list.
As are opinions on a whole subjective, I'd have to whole heartedly, though respectfully disagree with most of this UI critique. I also have been an avid user (no pun intended) of most DAW's from their beginnings. Actually Sonar being one, I've never used.
If you used S1 as long as you said, you'd probably know clips in Studio One are defined as "events". As to black outline, I think you are referring to an active or selected event. To my eyes, events are very clear, and possibly bolder in appearance in Studio One than PT (I'm a PT user from its inception). So lets just call this a difference of opinion.
Not sure what you're driving at. PT provides contrasting waveform color, just as S1. Slight differences, but perhaps you can define this in particulars.
- MIDI notes have some height to them and don't compete with CC automation lines.
Note height is easily tailored to user preference. Nor do i see S1 wqveforms competeting with automation lines. They are completely different tracks. Very transparent and usable. However, when automation is overlaid over tracks, I would agree PT's automation lines are clearer visually, and not hazing over waveforms when overlaid.
??? OK. Should I prepare some visual where S1 looks clearer over PT? Not understanding the point. More opacity control?
Higher resolution? Perhaps you mean clearer on your monitor? The waveforms are rendered differently if that's what you mean. S1 waveforms display different elements such as oscillations, or variences along with obviously relevant amplitude, where PT has more of the common RMS to sample amplitude resolution, only. This is a subjective call to waveform preferrence. Question: Would you also define Melodyne waveforms as having less resolution? They are just different interpretations of audio information.
Agreed. Different clip symbols though. Not sure which I prefer. Although the event/clip text in PT is larger, and therefore clearer.
- Much broader range of clip color options.
Agreed. Far and away, more colors with PT.
Each DAW holds to their own design concepts. Making music in a less distracting way will usually steer users to their preferred choice.
A few good points to be sure. Anyway, good luck going forward.
S1 Pro 4.1, Laptop: VAIO i7, 8 core, Win 7 64x. Audio Interface: Audiobox 22 VSL, Audiophile 192 PCI-e, Faderport 8, Controllers: Novation SL MkII, Roland JV-90, M-Audio Axiom, Guitar controllers: Roland GR-50, Percussion controllers: Roland Octapad, Akai MPD-18. MIDI Patchbay: MOTU 8x8, Sampler: ESI-32, Mixer: Yamaha Promix 01.
 My music
On Bandcamp
On YouTube
by 5Lives on Mon Dec 17, 2018 8:19 pm
Thanks for the reply! Definitely want to just start a conversation. I work in this field for a living, but that doesn't mean I have the right answers - just wanted to provide some food for thought. Very subjective of course.
Lokeyfly wroteIf you used S1 as long as you said, you'd probably know clips in Studio One are defined as "events". As to black outline, I think you are referring to an active or selected event. To my eyes, events are very clear, and possibly bolder in appearance in Studio One than PT (I'm a PT user from its inception). So lets just call this a difference of opinion.
I was referring to non-selected events actually. PT has the black stroke for all clips, not just selected. I do notice a very thin line on the edges for S1 events, but not on the top and bottom. I think Presonus could bump it by 1 or 2 pixels and also add to top and bottom to help provide some visual boundaries of events.
S1 always chooses a dark gray to display the waveform on an event, regardless of event color while PT displays the waveform a similar color to the event (just more saturated). Personally, I think this looks better.
Note height within an event is not editable though? And the Drums event in my screenshot clearly shows CC automation data competing visually with the MIDI notes.
More control over opacity could be an option (or they could just up the default). I personally don't think S1 looks clearer than PT in any regard when it comes to clips, but once again, that is subjective.
I have a 5k retina iMac - monitor resolution is not the issue :) The way S1 renders waveforms is not smooth, especially when you zoom in all the way (it is stepped). Logic, Ableton, and PT have all moved to a smoother display when zoomed in very close - I think one benefit of this is nicer looking waveforms when zoomed out.
Anyway, my 2 cents. S1 has great features, but I do believe the UI turns off folks from trying it - and we should want more people to use S1 (easier to work together, more money for Presonus for continued development).
by Lokeyfly on Tue Dec 18, 2018 12:38 am
Thanks for clarify8ng 5Lives.
-Pixel bump to borders on the non selected events. Never thought much of it, but sounds reasonable.
-Event color now understood via explanation.
-Yes, an automation overlay cannot be edited in S1. Drives me crazy. :roll: I want to overlay automation(s), but refuse to, due to non control.
-More control of events/clips in general. Opacity, etc.
-Render waveforms smoother, and less stepped. Thx again. For clarifying. Yes, smoother waveform graphics in this regard S1 could benefit from.
-And we know the color choices are too limited as well.
I think those few clarifications could help the cause, 5Lives. You might find some feature requests on a number of them as well. Good points made.
 My music
On Bandcamp
On YouTube
Users browsing this forum: reggie1979beatz, sirmonkey and 9 guests
