Hello!
I have Studio One 4.1.1, Kontakt 6 and the Scarbee Rickenbacker Bass instrument loaded into Kontakt 6. For whatever reason, the sustain function of this intrument is not triggered with the usual sustain controller (CC#64). It is done with a keyswitch on the keyboard. The problem now is that I have only a small keyboard with 25 keys. So this keyswitch is way out of range and not usable for me. What I need now, is a way to re-assign the MIDI, so that everytime I press the sustain knob on my keyboard (CC#64), the keyswitch (key A1) is pressed for Kontakt. Hope you know what I mean... Can this be done in Studio One? |
In Kontakt 5.8 with Scarbee Rick loaded ...
CC#64 = slide mode control A1 = use A string Maybe it's different in K6, but I don't find a sustain function anywhere except to keep the note key pressed. |
XoechZ wroteYes, you are right. There is no way to do that in the instrument. No, there is nothing native in SO that with translate CC to note on the fly. When I need a special config, I use a different preset on my controller and make the adjustments there. I still don't see a sustain function in Scarbee Rick. |
robertaccardi wrote Seems from your post that you were trying A0, which is an instruction to play on the A string. I see you were talking about A1, which is not a key switch for playing on the A string but is instead just to play the note A1 which is within the bass's range. But still, in any case, A negative 1 (A-1) is the key switch for sustain. As another reply stated, the actual sustain pedal triggers slide mode |
Users browsing this forum: JohHuisman, Lokeyfly and 92 guests
