1. I select an audio event
2. I Go to Audio>Normalize Audio (or Alt+N.)
Expected behavior: The audio is Normalized.
Actual result: Absolutely nothing happens.
I can Edit>Undo and the menu says "Undo Normalize." I do that, and I still see nothing happening.
I don't want to debate the merits of whether it is a good idea to normalize. I have a special need and I just want to get it done. Can someone tell me how to make it work? I am on Studio One 4.1.1 Pro.
Thank you,
-Charles
Studio One 4 Professional
RME Fireface UFX
Tascam US-20X20
Tascam US-16X08
Softube Console 1
FaderPort 8
lots of various pre amps, outboard compressors, etc...
by jih64 on Wed Nov 14, 2018 8:59 pm
I just used it the other day, works fine, as expected, Studio One 4.1.1. Must be something else going on.
You can also select/deselect the 'Normalize' box in the inspector for the track in question.
Jeff
Studio One 4 Professional - Windows 10 Pro 64bit
by Tacman7 on Wed Nov 14, 2018 10:03 pm
If a clip is at the right level it wouldn't undergo much change.
Have you tried a much lower level clip?
Melodyne Studio
Where 'IS' Shitcreek? and
by SwitchBack on Thu Nov 15, 2018 4:12 am
Also, what do you expect normalize to do?
Normalize will increase the overall level of a clip so that the very highest peak touches 0dBfs. So if that’s already the case then nothing will happen.
by miked7 on Fri Nov 16, 2018 11:33 am
What Switchbck said... ^^^ ...It sounds like you've got a big peak somewhere.
Mike Derrick | Studio One Professional 4.1, Windows 10 Professional 64, Dell Craptop, Intel Core i3, 8GB RAM, 500GB SSD, Tascam US2x2 Audio Interface
BandCamp
SoundCloud
by Fader Rat on Sun Nov 18, 2018 1:27 pm
Is there a place where you can enter the amount that you want to normalize an event?
OSX High Sierra, 2013 IMac, 8GB, 1TB, Studio One Pro 4.1 OSX 10.11.4-2007 2.4 ghz 4GB, 320 GB IMac
BLA modded Digi 002 rack
BLA Auteur Preamp
BLA B12A preamp
Apogee 24/48 converter
by miked7 on Sun Nov 18, 2018 5:50 pm
Studio One only Normalizes to 0dB. Then you can reduce the gain from there many different ways: grab the clip gain on the track and pull down, go into the Inspector and enter the amount of gain (you can also Check the Normalize box there), or go into the Macro Toolbar and reduce or add gain in 3 dB increments.
BandCamp
SoundCloud
by Neiby on Sat Jan 12, 2019 11:20 pm
I'm having the same problem. I have a clip (event) that peaks around -20dB and I want to normalize it. Absolutely nothing happens. It seems to think it was normalized, but no actual change occurred. I zoomed in the looked through the entire clip waveform and see no peaks, yet normalize does nothing at all. It's a little confusing.
by miked7 on Sun Jan 13, 2019 7:28 am
Can you use the macro mentioned above? Does it let you adjust the gain on the clip?
What if you dissect the clip and Normalize each section as you go. Keep chopping it into smaller and smaller segments until you find the piece that isn't allowing you to Normalize. Maybe there's a noise or pop or something that is peaking and you're not seeing on the wave form?
BandCamp
SoundCloud
by Neiby on Sun Jan 13, 2019 9:51 am
That's a good idea. I'll give both of those a shot and see what happens.
Users browsing this forum: michaelhoyt and 10 guests
