robertgray3 wroteHow is sequencing external instruments and then importing the audio a “workaround” and how do other DAWs make this easier? I also would like to know. I came to PreSonus from Cakewalk, where it was always done that way - my hardware synths have their midi recorded to a midi track when I play them. Then subsequent plays, the midi plays back the synths. When I'm done with the song and ready to start mixing, I just create an audio track and then record the synth to the audio track and mute and hide the midi track. That's how it was always done in Cakewalk, and when I came to Studio One, that's how I continued to work with external synths. I'm curious as to what this "external synth" method is that the other DAWs have as I wonder if there was an easier way to be doing this all these years. |
ionian wroterobertgray3 wroteHow is sequencing external instruments and then importing the audio a “workaround” and how do other DAWs make this easier? I mean I guess other daws make use of a track type to do this with one track? I think requiring two tracks for this and other things (like sending note events to an insert input) is a little inefficient but you still have to print the audio at some point to mix it, no? |
robertgray3 wroteHow is sequencing external instruments and then importing the audio a “workaround” and how do other DAWs make this easier? First off, what you refer to as "importing the audio" refers to taking an already-created file and placing it somewhere on your Arrange page; what we're talking about here is playing notes on, say, a hardware workstation like a Yamaha Motif or a Korg Kronos, often in real time (or they could be sequenced if the workstation has a built-in sequencer). External Instrument = for the point of this discussion, a hardware workstation, an older synthesizer, or a newer synth module or any device that has its own sounds you want Studio One to play. Compare that to playing software VST instruments through a keyboard controller which often has no sounds of its own. If you record notes on a MIDI controller you have set up in Studio One to play, say, a Kontakt VST, Studio one sets up a track in the Mixer page showing that track. If you record notes on your hardware workstation like a Korg Kronos, Studio One doesn't set up a track in the Mixer page showing that track. That is the huge inconvenience we're talking about, cause without a track in the Mixer window you have to make all the adjustments on your external instrument. Hopefully I wrote that so you can picture it in your mind. If, like growing numbers of people, you prefer playing VST instruments through keyboard controllers, you don't care. If you have a perfectly functioning, non-extinct external instrument, then some of us care enough to leave the fold and seek better, more conventional, necessary MIDI support elsewhere. |
MisterE wroterobertgray3 wroteHow is sequencing external instruments and then importing the audio a “workaround” and how do other DAWs make this easier? |
If the External Instrument is connected to audio inputs in Studio One so that you can hear it, it has to also have an audio channel in the mixer. In that regard you can treat the audio channel like any other audio channel.
I just use Pipeline on a bus channel to get synth audio back, direct injection, and render a stem of that when I want an audio file. That way I don't have to be monitoring an audio track to hear it. That way you also have one Instrument Track in arrange and one audio channel in the mixer, and Pipeline gives you the latency value on it's UI to adjust the Midi track forward to keep everything in time. Mmv on that method. It works for me. Renders are realtime anyway so, no method is really faster. |
That is also a good method too in terms of Faderport at least seeing that buss channel return allowing you to at least control the volume. (although it also means patching the synth directly to your interface instead of it going to the external synth mixer)
But unfortunately it does not solve the issue of Faderport being able to put the external midi track in and out of record, mute or solo etc.. It would be nice like Mister E is saying if the external midi track showed up in the mixer. And could send midi volume etc to the synth. Plus Faderport would also see it then and be able to do all its functions.
No idea what that means tbh. The instrument track has mute and solo buttons as does the mixer channel. You don't need a record button for audio as it records automatically on bounce or in my Pipeline case, print a stem. You can also send midi volume and pan directly to the external synth from the arrange track simply by adding CC 7&10 envelopes.
I mean, the Faderport doesn't show midi channels, only audio / mixer channels so I'm not sure if a midi fader in the mixer would show up there or not. Maybe. Maybe I misunderstand though. Anyway, sorry I couldn't help. |
Yes what you are saying is correct. An instrument track assigned to an external synth can do all those things except Faderport simply does not see it. The moment it is assigned to an external midi port on your interface (as opposed to a virtual instrument) Faderport does not know anything about it anymore.
Jemusic wroteIt would be nice like Mister E is saying if the external midi track showed up in the mixer. And could send midi volume etc to the synth. Plus Faderport would also see it then and be able to do all its functions. Nice seeing that sentiment from a mod. What would be nicer still would be seeing some official statement from Presonus developers along the lines of "We know that some of you have been wanting for years to have a channel appear in the Mixer representing your external instrument. We're not going to ever do that because of this and that ... " or, "We are going to do that at some point because of this and that." Is that really too much to ask? All we've ever heard from the company is its initial statements about what a great advantage it is to treat MIDI differently from other DAWs which appeared in the original manual from like 2011. If I was a Presonus developer, by this time I'd be sick of reading about how people doing serious MIDI composing have to go elsewhere for satisfaction. But that's just me. Once again, we are not talking about a feature. We are talking about basic functionality offered everywhere else. But maybe I just don't understand? OK, then. Enlighten me already!!!!!!!!! p.s. Lawrence you're like the biggest S1 power user out there or at the least you're in the discussion. It's great that you've figured out a workaround that works for you, but it shouldn't require a deep programming and routing mind for a typical "user" to get the most out of their external instruments. |
MisterE wroteWhat would be nicer still would be seeing some official statement from Presonus developers along the lines of "We know that some of you have been wanting for years to have a channel appear in the Mixer representing your external instrument. We're not going to ever do that because of this and that ... " or, "We are going to do that at some point because of this and that." Yep. PreSonus never gave any statements about future features, functionalities or release dates. Anybody knows that if he has been following the development of Studio One in the last years. But you can be sure that PreSonus knows everything about user wishes and needs out there And as I already mentioned the answers feature database is one thing they really pay attention to (just look at the features with many votes that already have been implemented). But I know, you're not willing to vote there MisterE wroteAll we've ever heard from the company is its initial statements about what a great advantage it is to treat MIDI differently from other DAWs which appeared in the original manual from like 2011. It is a great advantage that results in a big flexibility. And it has nothing to do with features not being there yet
Lukas Ruschitzka
Indeed too much to ask. If they do that I would expect them to comment on all the other feature requests as well. Probably unreasonable.
I would hope however that they would comment on verified bugs myself, that's where I expect interaction. Anyway throw me the faderport feature request link and I'll vote on it.
I am assuming once an external midi track appears in the mixer (feature request) then Faderport should see it like all the other channels or one would hope.
I think this is the link you may be referring to: https://answers.presonus.com/20758/inst ... 758#q20758 This request has only got 13 votes. (I voted!) but that is not high obviously. Unless there is another request that is very similar that has a lot more votes.
MisterE wroteFirst off, what you refer to as "importing the audio" refers to taking an already-created file and placing it somewhere on your Arrange page; what we're talking about here is playing notes on, say, a hardware workstation like a Yamaha Motif or a Korg Kronos, often in real time (or they could be sequenced if the workstation has a built-in sequencer). Sorry, I meant “importing” in a general sense as I route my external synth outputs to an audio track and simply monitor them then record it when I need to print an audio track from them. I have six or seven external moduels that I play through Studio One, I’m aware of what you’re talking about. But so far aside from Faderport recognition I’m not hearing anything terribly specific about what this feature entails. I haven’t used whatever DAW has this feature (Cubase?) so nothing is immediately coming to mind. Maybe put it in a bullet point list in a new post. So far it seems like “Channel Pan / mute / faded assigned to MIDI standard pan / mute / volume CCs” and “built in audio track for monitoring/record” seem to be what you’re getting at? Don’t get me wrong, I don’t like setting up multiple tracks to represent one external instrument but most of the requests I’ve seen on this tend to focus on “implement this basic functionality” instead of articulating details. |
Jemusic wroteI am assuming once an external midi track appears in the mixer (feature request) then Faderport should see it like all the other channels or one would hope. No, this is the correct thread/ticket: https://answers.presonus.com/22832/stud ... show=22832 Means the same as yours, but is a bit more precise although it already suggests a concrete solution.
Lukas Ruschitzka
[quote="robertgray3"So far it seems like “Channel Pan / mute / faded assigned to MIDI standard pan / mute / volume CCs” and “built in audio track for monitoring/record” seem to be what you’re getting at? [/quote]
Exactly regarding the first half of your sentence, that's for the basics. Though I don't know what you mean by “built in audio track for monitoring/record”. We already get one of those on the Arrange page; it's the Mixer page where a channel doesn't get created. Then there's more exotic "patch script" stuff on offer by Cubase etc on top of it, to mention one nicety, whereas patch names are simply not supported by S1. I don't want to keep discussing this since Presonus is content to be the only major DAW player that's prejudiced against a certain kind of track. I check back here every big release to see if anything's changed, it never does, and there's no reason to hope against hope that it ever will. |
MisterE wrote[quote="robertgray3"So far it seems like “Channel Pan / mute / faded assigned to MIDI standard pan / mute / volume CCs” and “built in audio track for monitoring/record” seem to be what you’re getting at? Exactly regarding the first half of your sentence, that's for the basics. Though I don't know what you mean by “built in audio track for monitoring/record”. We already get one of those on the Arrange page; it's the Mixer page where a channel doesn't get created. Then there's more exotic "patch script" stuff on offer by Cubase etc on top of it, to mention one nicety, whereas patch names are simply not supported by S1. I don't want to keep discussing this since Presonus is content to be the only major DAW player that's prejudiced against a certain kind of track. I check back here every big release to see if anything's changed, it never does, and there's no reason to hope against hope that it ever will.[/quote] |
lisarowe wroteBobF wrotetommikujala wroteIs there a bug in "merge to stereo file" command in browser, when you select two mono audio files and right click. Crashes here on S1 4.1 mac OS X 10.13.6 Great news! Studio One v4.1.1 was released today (10/30/2018) and this problem has been resolved. Thanks for your patience!
Users browsing this forum: AAV and 30 guests
