Dear Studio One Users,
our latest update - Studio One 4.1 - has just gone live. We've added support for our new ATOM pad controller and a few more new features and improvements. Have fun! Arnd ____________________________ Studio One 4.1 Release Notes New features and Improvements:
• New Pipeline XT plug-in for routing of external effects • Extended Note Repeat with keyboard remote • Tempo Automation • Beat-linear timeline option • Improved manual tempo mapping with Scale Time tool • Tap tempo via keyboard shortcut • AAF export options (including embedded AAF support) • Import Song Data from song template • New “Cue mix mute follows channel” option • New look for External Device panels and QWERTY Keyboard • The macro bar now stores the last page viewed per editor • Select Highest or Lowest notes more accurate when overlapped • Key command mapping for "Song Setup" dialog • Tempo map added to rendered click file • Improved zoom and scroll behavior in Pattern Editor • [Windows 10] System DPI scaling option for third-party plug-ins • [Windows] “Enable High DPI Mode” option is back The following issues have been fixed:
• [macOS] Accessibility zoom breaks context menu • [macOS] Deadlock on clicking main menu bar with system file selector open • [Windows] Help Viewer doesn't adapt to different monitor DPI • [Melodyne] Editor not immediately opening on edit • [Chord Track] Wrong detection inside arpeggios • [Chord Track] Accidentals not displayed correctly in the pop-up selector • [Drum Editor] Unwanted double notes when duplicated • [Drum Editor] Duplicating notes with swing are placed in wrong location • [Track Inspector] Automation controls background missing • [Track Inspector] Event FX container doesn't remember size • [Track Inspector] Automation parameter select-box text is hidden by color field • [Presence XT] Ping Pong looping issue with short samples • [Presence XT Editor] Crash on copying zones • [Impact XT] Amp envelope should be exponential • [Impact XT] Missing "Cancel" button on initial sample search • [Impact XT] Pad Names are overwritten while editing (user vs file name) • Macro toolbar scripting error • Pitch editing doesn't accept B from keyboard, changes it to A# • Enabling Note Repeat aftertouch + playing aftertouch causing infinite note • REX file import issue when song sample rate is different from file • Playback of stretched audio sometimes incorrect • Remotes do not generate undo steps for all parameter changes • Wrong waveform drawing when creating loop range • Potential crash when opening detached audio editor • Channel macros lost connection to parameters on Import Song Data • Steps placement is incorrect when duplicating a Pattern • Plug-in thumbnail icon not inverted in light theme • Applying Mute on mouse down causes audible clicks • Crash on save after removing Multi Instrument • GUI artifacts while scrolling w/ TAB thru track name fields • Copying an event from a folder pastes it on a new track • Song parameters are reset when Time Base is changed to Frames • Wrong inverted note selection in a duplicated (shared) part • Wrong automation result after moving arranger section • "Move" and "Copy" w/ Ripple Edit on the same track deliver different results |
