Starting with s1 pro v4 I’m having all sorts of problems loading the latest plugin alliance bx plugins (ssl, mastering desk, ssl buss comp)... the behavior is this: drag plugin alliance onto a track but the plugin doesn’t populate.
This seems be a problem with existing songs... I I start a brand new song with zero plugins the plugin alliance box plugins instantiate just fine... trying it on an existing tune (even one created in v4 +) it’s a no go It doesn’t seem to matter if I have my buffer set to 32 or 4048... even when I have almost nothing moving the cpu monitor. I know others are experiencing the same thing but get run off the 4.1 discussion thread when they bring it up. What’s the problem??? Anybody come up with a solution?
https://soundcloud.com/brotherbrim/sets ... ernational
win 11 pro... S1 pro latest version... 64 bits... Rme latest drivers... All the ram and i9 3900k monster... |
Have you tried reinstalling your PA plugins? I seem to recall they came out with some updates recently. Maybe the older version is somehow locked into SO3? Just a guess. Sorry, I haven't had any issues.
Studio One Pro 6.5 | Apollo Twin Duo USB | Win10 | AMD Ryzen 3 | 32GB RAM | SSDs SoundCloud | Project 9732 | Komplex 2 |
For what its worth (and a great song)
I think all but one of these had an update. I just installed them. One of them (stereo or shred) would not show up not matter how many times i dragged it. Then after loading some of the other ones it would drag and show up. Now they all show up and seem to work. Tried on a current 4.01 song. Not through heavy paces. ymmv I dont use them much these days. Dont know why, i liked shred and stereo spread. meter opto rockrack shred spread stereo maker Maag eq spl attacker
Win 10 latest, MSI G41 Z87, I4770K (no OC), 16GB, NVIDIA 710, 2x27" Monitors 1Tb SSD, 500G SSD, 3 platter drives. SYBA Firewire SD-PEX30009, FS Mobile. Monitor2USB, S1 Pro 5 current.
Hobbiest - Mainly Guitars, UVI, Soundtoys, NI, IK, EZ2, SD3, GR5, TH3, Amplitube 4 and 5, Waves GR, Korg 707, NanoPAD2, MicroKey2. Eris 5, B2031A, 2013 R1200GS-LC. |
@brettgoodkin
I would try just one of the plugs on an older song and see if it shows up. Then another until you can narrow down the plug(s). If they all don't show, you may need to uninstall them and reinstall. You can open a support ticket for this as well. You will need to provide them the exact versions you are running for Studio One and your plugs. Thanks. |
For clarity’s sake:
This behavior is present on the neve and both new ssl bx channel strips, the townhouse compressor and the brand new bx master desk I suspect that it may have something to do with the zero latency deal within s1.... Again, I know I’m not the only experiencing this in s1 on Windows 10, so I’m hoping the other cats show up and sound off
Here's stab in the dark:
I had a similar problem (if not the same) with another plugin manufacturer. After a while, I noticed that the problem only occurred when I had wifi on. But I had no problems when wifi was off. It had something to do with some "permissions" thingy. So, you might see if the behavior changes when wifi is on versus off- before starting up Studio One. |
sirmonkey wroteHere's stab in the dark: Hmm... I don’t have a WiFi card in this machine... I DID notice a benefit shutting down virus protection
Not quite the same issue but when I open a session in progress random BX Console E and BX Console SSL 4000 E show as "Missing Device". I'm on S1 v3.5.6. PA support has been no help whatsoever a month in. Just opened a ticket with Presonus. I've uninstalled/reinstalled everything to no avail.
Users browsing this forum: BobF and 79 guests
