Long-time Cakewalk/Sonar user here...
When I open an audio file created in Reaper using iZotope RX6 Advanced,
it displays the changing tempos from Reaper.
Studio One Pro 4 - does not.
Other than importing a MIDI tempo map, is there any way to get Studio One Pro 4 to see markers in an audio file created with Reaper?
Since RX6 Advanced can do it, I know it's possible!
Thanks,
MG
Add "Include Mix FX" Check Box when saving Custom FX Chains: https://answers.presonus.com/73924/save ... x-channels - THUMB IT UP!!
Windows 10 Pro x64 running on a custom tower PC with ASUS Pro WS X299 Sage II MOBO/ LGA 2066 Intel Core i9 X (12 Core), 64GB RAM, 1TB M.2 (OS), 2TB M.2 (Sample Libraries) 2TB SSD for audio, 1TB Raptor Audio Backup, 4TB Storage/Backup Drive, (1) UAD2 Octo, (2) UAD2 Quad, Lynx Aurora 16/AES16e, Radeon RX 570 ROG Video Card
by Lokeyfly on Tue Aug 14, 2018 3:31 am
Have you tried setting Reaper as a Rewire host, and slave Studio One.
I no longer have Reaper on my computer, but it's pretty common to hook up one DAW to another via Rewire protocol. Tempo changes are part of that protocol where the slave program will follow any tempo changes.
I do this with Reason and Studio One all the time, so just checking if you explored that.
S1 may not show markers (as in flag location markers) but it will slave to tempo change locations.
I'm thinking if you then need to drop Reaper out at some point, you probably could record those tempo changes. That, I'm not sure. You might have to then map those changes.
Another way would be to import Reapers song data, if it contains tempo changes.
New song "Our Time"
https://youtu.be/BqOZ4-0iY1w?si=_uwmgRBv3N4VwJlq
Visit my You Tube Channel
https://youtube.com/@jamesconraadtucker ... PA5dM01GF7
Latest albums on iTunes
All works registered copyright ©️
by DrummaMan on Tue Aug 14, 2018 10:46 am
Thank you for chiming in Lokefly.
A tad more info is needed to clarify -
A client, who uses Reaper, sent me two audio files:
1) Click
2) eGuitar
I need to make SOP4 sync up so the grid matches Reapers, as the drummer is going to track at my studio.
There are no time signature changes - only tempo changes.
When I first received the files, I opened them to get the stats/interlacing, etc. of the files using iZotope's RX6 Advanced.
RX showed not only what the files were recorded at, and whether or not they were stereo or mono tracks - but also displayed the different tempos as markers.
SOP4 only imports the files and shows no markers and only the default tempo.
I'm just wondering if it is possible with SOP to import the Reaper audio files and display the markers without using a midi file tempo map.
From what I've seen... it is not.
Users browsing this forum: christianmiekus and 66 guests
