Looks automap 4 can't recognize studio one 4 - anyone have a solution?
Hmm I don't know anything about specific support, but SO4 should be able to use any general midi controller if you just set it up as a general midi controller. I find sometimes it's a bit weird/finicky and you have to play with some settings but it should work. For instance, if you have a softsynth/VST open, make sure that in the arranger window the correct midi input is selected. So make sure the input for Novation Impulse is selected.
I'm using a Korg MS2000 as my midi controller in SO3 so I'm sure an Impulse 61 would be fine...I mean my controller is literally 18 years old lol. The pitch wheel doesn't send midi data but oh well! |
Have you set you controller up for Mackie HUI control?
Have a look at the following video at 4:13 and forward. It's for Studio One 2, but it should be the same. I don't have Studio One 4 or Novation Impulse, but i have Studio One 3 and Novation SL MKII.
Motherboard: Intel DH77KC
Yes - but i guess you can't use that guide for Studio One 4 - at least yet. That's why i gave you the time in the video. You can set it up manually without the guide, and that's shown in the video too.
You just set it up thru Studio One 4 directly. If you have Syudio One 2, and have used the guide for that, then simply redo the settings in Studio One 4 manually.
Have you tried to just set it up thru Studio One directly as i suggested no matter Novation has announced a support ot not.
Just try and do this: 1. Be sure Automap is running on your computer. 2. Open Studio One. 3. In Studio One - Go into the top menu Studio One/ Options/ External devices. Just do like shown in the video i posted at the time i posted. 4. Perhaps restart Studio One and perhaps also your computer. All this can be done without the automap app guide that you have posted images for. Did it work?
Am looking it up but think the MCU control could do it and then setup as keyboard as well.
Sorry to say my solution did'nt work but in Cubase 9.5 I used the Cubase 8 Automap settings and it did work as well in 9.5
Have since deleted Automap as I use Faderport 8 instead so am not able to test further. Maybe the SO3 setup will work also ?
Actually it works, you just need to install the Automap 4.11 start it and use the Studio One 3 setup
I ignore the plug-in mapping in general but you don't have to and it worked as a transport controller except for the loop button ?
Users browsing this forum: No registered users and 80 guests
