1 post
Hey all..Transform audio from 2 pattern variations is not printing correct. The first note or kick drum in my example at the start of the second variation, bar 3 is missing. This works fine when you convert the pattern to a part and merge the 2 events.
Is this intended or a bug maby?
I have one instance of Impact XT with drum samples in and no plugins activated so latency is at 0.
As you can see from the image the Kick drum at bar 3 is completely missing after the pattern is transformed to audio from 2 pattern variations side by side and it clearly has note data there in the pattern track. This never happens when its transformed to a part first.
Sorry for bad pics. :)
Pattern file.PNG (2.48 KiB) Viewed 159 times
PatternTrack Transform.PNG (5.96 KiB) Viewed 159 times
Track Part Transform.PNG (9.12 KiB) Viewed 159 times
Windows 10 64-Bit, i7 6700k 4.5 GHz, Asus Z170-A,16GB RAM, 250GB Samsung 850 EVO SSD, Studio One 4 Professional 64-Bit, Steinberg UR44.
1 post
Users browsing this forum: bryanmiller5 and 17 guests
