32 postsPage 2 of 2
1, 2
Thanks everyone for their suggested work arounds and alternative options for accomplishing what I seek. They should work in the interim. But I definitely believe that having the freedom to select to transform PRE as well as post fader is the most streamlined, convenient and professional way of temporarily rendering tracks to free up your CPU usage in a modern daw such as Studio One. Thank you so much for your votes and keeping my dream alive. I recently upgraded from 3 to 4.1 and have to say that pretty much every missing feature from studio one I have been hoping for has been implemented (better tempo mapping, session data import etc.) EXCEPT this one so I will continue posting and bumping it in hopes of getting more peoples attention and votes until hopefully it is implemented and I am a happy man.
Thank you again for your replies and votes! Cheers!
by robertgray3 on Fri Sep 28, 2018 10:00 am
Thanks for pushing this, yeah I wish for this just about every time I transform a track!
Mac OS X Mojave 10.14
Mac Pro (Late 2013)
3 GHz 8-Core Intel Xeon E5
32 GB 1066 MHz DDR3
Dual AMD FirePro D500 3072 MB
by vseanv on Fri Sep 28, 2018 12:53 pm
robertgray3 wroteThanks for pushing this, yeah I wish for this just about every time I transform a track!
No problem! Thanks for your comment and hopefully it gets implemented sometime soon. It's unfortunate I haven't been able to get more votes with this post being viewed over 600 times but every vote counts and I appreciate it!
by mikemanthei on Sat Sep 29, 2018 8:57 am
As long as you're on the subject of things that should be pre fader, add stem export to that list.
Studio One v3 Professional
Presonus 1818VSL / Focusrite 18i20
6-core Windows 7 64bit - 2.8 GHZ - 8GB RAM - SSHD
Presonus FaderPort 8
by vseanv on Sat Sep 29, 2018 9:59 am
mikemanthei wroteAs long as you're on the subject of things that should be pre fader, add stem export to that list.
Definitely.
by vseanv on Thu Oct 11, 2018 11:04 am
By weekly bump!
by vseanv on Fri Dec 14, 2018 12:59 pm
Bump because I have moved back to studio one from PT full time and this is the only feature that is causing me a huge PIA... please pretty pleaseeee
by rjplus on Fri Dec 14, 2018 7:43 pm
Can't you just do a pre fader send to a bus and render the bus. Its an extra step but should do what you want.
Roy
by bailatosco on Sun Dec 16, 2018 12:41 pm
Of course this is really needed. I read praises on some forums about S1's Transform function and I wonder what are they comparing it to. I mean I use it, it's there, but it's not a "mature" feature by any stretch.
The default behaviour should have been "pre fader/pan" from the beginning, that's a given. But the functionality could improve a lot, here's some examples inspired by Reaper's freezing system, wich is really good at this:
- freeze ANY track, bus, fx. (maybe if you freeze a bus, the bus turns into a stereo audio track, and the tracks that are sending to that bus get disabled -and hidden?-)
- multiple Transform steps: you have a plugin on a track, you freeze it, you put another plugin, you freeze it, you unfreeze the track and the last plugin you inserted appears on the track again, you unfreeze again --> now both plugins appear on the track.
Anything that can help you save some CPU in Studio One, is the best thing the developers can do for Studio One.
Intel i7-6700K OC'd to 4.4Ghz / 16Gb RAM
WIN 10 64bit
Studio One v3.5 Professional
Audiobox 1818vsl
by bailatosco on Mon Dec 17, 2018 12:22 pm
I forgot something that would also be a nice addition to the Transform feature (inspired on Reaper too):
- When you transform a track, only the ENABLED plugins get rendered... and the ones that are bypassed or disabled stay on the channel. IMO this is a must-have.
I found some feature requests for the functions I mentioned above:
Transform bus channels to audio (freeze bus)
https://answers.presonus.com/16290/abil ... 290#q16290
Transform to Rendered Audio to include selected Plugins Only
https://answers.presonus.com/14876/tran ... 876#q14876
I think it would be really nice to unify all these feature request into a unique "FR: Transform to rendered audio features"
WIN 10 64bit
Audiobox 1818vsl
by vseanv on Sun Dec 23, 2018 11:30 pm
rjplus wroteHi,
Roy
This would stull result in a reset fader/pan automation.. I want the automation to remain separate from the frozen file so it is always maintained and editable.
by vseanv on Sun Dec 23, 2018 11:31 pm
bailatosco wroteI forgot something that would also be a nice addition to the Transform feature (inspired on Reaper too):
Thanks for your replies, I agree with you completely! I also really love the way reaper does a lot of things except comping.. but i’m starting to feel like I might bite the bullet and adapt to it’s modus operandi and start using it instead.
32 postsPage 2 of 2
1, 2
Users browsing this forum: gwp9999 and 18 guests
