31 postsPage 2 of 2
1, 2
Update...rebooted computer, plays fine lol.
by justinfriedman on Mon Jul 27, 2020 1:52 pm
by scottyo7 on Mon Jul 27, 2020 1:57 pm
The sample rate in your song needs to be equal to the sample rate that your Audio Interface is set at.
So ensure your AI sample rate isn't getting changed* and/or ensure (or try) that you export your song at that same rate.
*new version 5 feature, default or bug?
-S1 Pro 5.5.2. Win11 Pro 22H2. Behringer UMC404HD. Melodyne Studio 5.3.1.018.
-MSI 12th Gen i7, 16GB, 1GB SSD x2, 7200rpm 2TB HD, NVIDIA RTX 3060.
-EZD3 & EZD2. Helix Native, Scuffham S-Gear. iZotope Ozone 5.
-Akai MPK249. 6 Guitars. Line 6 Helix LT, 2 POD's & an E-bow. 8-)
-Adam Audio T8V's. Dual 28" ViewSonic Displays. Rode NT1. SM58. Original Faderport.
-Just My Songs
-My Previous Band: 2GUYZINABASEMENT
by patricknehlawi on Mon Oct 05, 2020 12:00 am
Has anybody found the solution to this problem? I've also tried a few media players, none of which work for my exported mp3's or .wav files.
by rickysouder on Thu Nov 05, 2020 9:50 pm
I have no issues with mixdowns playing for me however, I do seem to have issues for them playing for other people on Facebook messenger.. Its weird because I can send same file to 3 or 4 people and 2 of them will not be able to play it? I can hit the song on their messenger after I send it and it'll play but wont for them on their side..
by cdricblanqui on Fri Nov 06, 2020 8:57 am
Maybe stupid but ...
Did you check the "release audio interface" box in the option ?
(If S1 is open and the box is not checked, nothing will play any audio file outside of S1)
And you have to minimize S1 too if you want to play a file ...
W10 Intel I7 16Gb
SO V5 Artist & V5.2 Pro (in Sphere)
Studio26c / Atom / Monitor station V2 / Faderport 16
Akai MPK mini / Roland A49
Eris E5 / AKG K702 (+ Sonarworks)
by levibolonyi on Fri Jan 01, 2021 6:36 pm
Hi everyone. I followed all your instructions but the saved MP3 or wav file would not pley. On the player I can see it but is mute with no sound.
Did any of you found out what is the issue?
Thanks,
Levi
by anthonydonald on Tue Dec 07, 2021 10:32 pm
I am having the same problem. My MP3 player is working fine, but anything I mix down in Studio One 5 doesn't play. I have tried MP3 at both 44.1 and 48, using 320, 128, as well as wave, nothing plays. It opens Media player, just sits there, same with Groove. The MP3 files are 11MB with 320 and 4.6 with 128, and the wave was 49MB, so about the right size. This is bizarre. My mixdowns in Cakewalk work fine...
Studio One Artist
Intel(R) Core(TM) i7-8750H 2.20GHz 16 GB Ram Win 10 64
MacBook Pro 2.2 GHz I7 16 GB Ram Big Sur
Quantum 2626
Faderport 8
by leosutherland on Fri Dec 10, 2021 4:21 am
So you are using S1 and you mixed down MP3, and the MP3 does not play. Did you try rebooting your machine without starting S1, and then trying to play the MP3?
This is to do with the possibility of S1 not releasing the sound engine as mentioned above, so doing the reboot and not starting S1 would stop S1 hanging on to the sound engine.
Just my tuppence worth :)
...said Halo
Studio One Pro v4.6.2 / v5.5.2 / v6.6
Serum, Diva, Synthmaster, MTron Pro, Kontakt 6/7, Cherry Audio synths, Battery 4 etc ad nauseam
3XS SQ170 Music Studio PC
Windows 10 x64 (22H2)
i7 8700 Hexcore 3.2GHz, 16GB, 2TB 970 EVO+ M.2 NVMe SSD + 1TB SATA HD
Scarlett 2i4 (G2), Korg Taktile 25, Faderport 2018, Maschine 3
Beyerdynamic DT990 Pros, JBL 305P II speakers
by Tacman7 on Fri Dec 10, 2021 8:26 am
Are you able to play the file from inside S1? (find file in browser)
See if it actually has sound in it. I've had mp3's not play because of sample rate mismatch.
But different interfaces have different methods because some I have no problem doing anything I want to do and others have some problems.
Used to run 48k in the DAW and 44.1k for windows. I changed windows to 48k but it can still play 44.1.
I've had other interfaces that wouldn't play the other sample rate.
Maybe export a 10second version to post...
Win10 Ryzen 5 3600 - Motu M2
by joshuadelaughter on Fri Apr 29, 2022 6:34 pm
I know this is an old thread, but I had the same issue and just found the solution. Studio one hogs your audio driver for whatever reason. You will have this issue with anything as long as Studio One is still open. Once you close it, it should work.
31 postsPage 2 of 2
1, 2
Users browsing this forum: AAV and 63 guests
