Whenever I click the monitor button on a channel strip, the strip starts blinking. As it alternating between bright and dark of whatever the color the strip is at the moment.
Is this a new feature? This just started happening while doing some overdubs, it wasn't earlier tonight. If this is a new feature (or old one I just didn't know about) where's the toggle to turn it on and off? |
I assume you mean the PreSonus Channel Strip
There is no monitor button on the Channel Strip itself. I assume you mean on the track header. Not normal behaviour. Channel Strip does not blink or is supposed to.
Jemusic wroteI assume you mean the PreSonus Channel Strip Interesting. Here's a gif I took of the behavior. Note it starts when I hit the monitor button and stops when I turn it off. Just double checking this isn't correct behavior before I file a bug with Presonus. |
Ok I thought you meant you were using the actual PreSonus Channel strip plug-in but from the attachment I see you mean just the actual channel as a whole. I will look into again for you.
I also see you have got Console 1 inserted as a plugin. Can you remind me please what that is. (Is that the Softube control surface) And it is also in Low Latency Monitoring mode as well. Try taking that instrument out of LLM mode. Try turning each of those plugins off one by one e.g. the UAD plugin and the Console 1 plugin as well. See if it happens then. I see there is a burst of CPU usage as well when you do this. Open up the performance monitor in Studio One and click on show devices. See if anything in that ist is consuming high CPU resources. What Mix FX have you got going as well please. Don't report anything until we rule what may be causing it. It may mean something that we just have not seen before.
So i spent some time and narrowed it down. It's being caused by the VST 3 version of the Console 1 plugin when Low Latency mode is enabled.
I have a session file that demonstrates it now: create a single audio track, enable low latency, insert the Console 1 VST 3 plugin. Channel blinks. Note, I tried in S13 and it doesn't happen. I'll submit a bug to Presonus. |
Users browsing this forum: No registered users and 73 guests
