42 postsPage 3 of 3
1, 2, 3
Hi Robert,
Yes, they are all the loops that are included with Studio One Pro.
In those, there's all the effects, chord progressions, and single shots.
PreSonus also offered some loops from a company called "Nine Volt Guitars" which were added a few years ago... in there.
I've only added some thunder and rain loops myself into my soundset folder.
So to be clear, I used to be able to just drag and drop loops from those soundsets located on my external USB 3.0 1TB Western Digital drive (via the S1 browser) into my song and they always worked. I usually left them 'as is' and only bounced a few but not in every song, so I cound transpose, etc..
I had a couple songs to finish in 3.5.6 so after that, I upgraded to 4.0.1 and that's when the issues immediately started. I found the only way I could keep using the soundset files from my externnal USB 3.0 drive was to always bounce them. But now that I've moved them all to my internal SSD drive, I can once again leave them in their most virgin state. This I do so that I can only manipulate them if needed - cuz if I bounce here and there and make edits weeks into a song, I'm commited. 8-)
And yes I understand that if I load a bunch of "Instruments" that could cause performance issues or audio dropouts but the songs that exhibited this when I first started using 4.0.1 were very simple and short arrangements. I've since removed the folder containing my test songs and files since I've resolved this issue for myself... but it doesn't answer the question as to what PreSonus changed in version 4 that now causes this?
Scott
If you've not already done so...
Please add your Signature & Gear Spec's to your Profile
Here.
ASUS Laptop, i7 3820QM; 16GB; 2 Samsung 840 SSD's; NVIDIA GTX 670MX; Win 8.1.
S1 Pro 4.6; EZD2 2.1.8. Behringer UMC404HD USB A/I.
Synths: Alchemy, Air Tech Music Suite.
Melodyne Studio 4.2.4. Ozone 5, (all 64bit).
Akai MPK249. 6 guitars. 2 Line 6 POD's & an E-bow.
Fluid Audio FX8 monitors; Dual 28" Displays. Rode NT1; SM58. Faderport;
-My Band: "2GUYZINABASEMENT"
-Just Me
by snb1 on Tue Sep 04, 2018 11:22 am
snb1 wroteI've had the same problem for a while now dating back sometime in v3 and was one of the main reasons I couldn't dive into audio manipulation like I wanted to. Until today when I came across this post and seen you have the same issue so I was inspired to find a work around. I found that if you put Melodyne on your audio before any time stretching, everything will work fine. So pretty much treating Melodyne as the time stretching engine if that makes sense. Try it and let me know if it works for you.
Disregard this message, this is not a good workaround lol. Im going to tryn and reboot and see what happens because this is getting real annoying.
Studio One Pro 4.5.4 64 bit, Mac OS 10.12.6, Mac mini (Late 2012) 2.3GHz quad-core Intel Core i7 (Turbo Boost up to 3.3GHz) with 6MB L3 cache, Intel HD Graphics 4000, 16 GB ram, 240 GB OWC Extreme Pro 6G Solid State SATS Drive startup disk, 1 TB internal SATA Dive, (2x) 1 TB External Glyph Studio 7200RPM eSATA Drives, 500 GB External WD Drive
42 postsPage 3 of 3
1, 2, 3
