34 postsPage 2 of 2
1, 2
My reluctance to embrace the FP 8/16 comes directly from my experience with the FP 1.
Something as simple as changing << >> to Back measure/forward measure requires an unsupported change to the config file that gets wiped out on the next update.
OTOH, using the FP1 strictly as a single motorized fader along with an LX61+ (which IS fully configurable without being wiped out by updates) is a pretty good solution for me for now.
When I go multi-fader it will be with a fully configurable piece of hardware or not at all.
Studio One Pro - latest
Win10Pro x64 (latest) i7-6700 @3.8Ghz / 32G / 43" 4K
UMC1820 / Event PS8 / FaderPort Classic / KKS61MK2
Maschine MK3 / Waves Gold / Nomad IS3 / IKM Max / K12CE
by Jemusic on Thu Jul 12, 2018 7:22 pm
FP1 (Classic) and FP8/16 are nothing alike. FP1 (classic) is also a very old product. It is unwise to base anything on FP1 in terms of FP8/16. There have been firmware updates for FP8/16 which are only making them better still.
The rotary encoder now on FP8/16 scrolls one bar at a time standard. No special adjustments required and it always works that way.
The LX61+ looks like a nice controller for sure but even coupled with FP1 will be nowhere as deeply integrated as FP8/16 is currently with Studio One.
The thing with FP8/16 is you will never know any of it until you actually get it hooked up to your system. Then after a few weeks you will wonder how you ever lived without it. It makes fast operations possible too in Studio One. Really reducing mouse and QWERTY keyboard operations. Speeds up workflow in a major way. If you can get a lend of one I would look into that option.
I have worked with FP 1 (Classic) for a long time too. What I have found is even with FP8 having 8 faders in front of you actually improves your mixes. The fact you can look at any group of 8 channels at once and just fine tune them for balance puts you closer to a nicer mix. My mixes have actually improved since using FP8. FP16 would be even better in terms of seeing any 16 channels at once as well.
You can look at all tracks or just audio or midi or VCA's or buses. It is easy to navigate large sessions. Faders can show sends and also edit all the Presonus plugin parameters. I am pretty sure third party plugin parameters can be setup to also be controlled from the faders when asked to.
by BobF on Fri Jul 13, 2018 5:24 am
Am I able to completely configure any button/knob to do whatever I want them to do?
The LX61+ has very tight integration with SO provided. I don't use that. Instead, I have setup every knob/button/slider to exactly what I want them to do, not what Nektar set them up to do. It's actually set up as 3 devices in my system.
I haven't ruled out FP8/16 completely. It's just a big unknown at this point. What I'm really talking about is the ability to get an FP8/16 into a pure MIDI mode so that I can freely map everything in SO and other DAWs.
For example, I am able to use the FP1 with Reaper only thru the kindness of strangers that have provided a plug for Reaper that will handle it.
by patm300e on Fri Jul 13, 2018 10:14 am
I was looking into the FaderPort 8. I do have a FaderPort single channel and I still have it hooked up and use it. The single faderport has been rock solid for me and there is only one reason I got the X-Touch instead:
1 single $499 device controls Studio One AND my XR-18 interface with a single button to toggle between the two. That is what sold me. Yes, it will take a bit of getting used to the same buttons doing different things, but so far, I am happy.
BTW for the X-Touch users, I am almost finished the document I created for Studio One mapping too! When I get done, I will upload it.
Studio One 4.1 Professional on Home built i3 16 GB RAM 64-bit Windows 10 Home Premium 120GB SSD (OS) 2TB Data Drive. Behringer U-Phoria UMC204HD, and/or XR-18 USB 2.0 Interface. Single FaderPort , Behringer X-Touch control. Ozone 8 Advanced, Various Waves Plug-ins.
by klausegon on Sat Feb 01, 2020 3:45 am
Jemusic wroteIf anyone is considering a control surface for Studio One, Faderport 8/16 is way ahead of any other device. Trust me on this.
Unfortunately i cannot agree!
I compared both and I'm very disappointed about Faderport.
1) I'm missing panning knobs. For this function you have always to switch.
2) I'm missing a fader for master volume. In my workflow it is very uncomfortable, when during adjusting channel volumes, there is no direct access to master volume.
But this is not main course, the most disappointed point is is
3) the faderport control was not able, to control more than 8 parameters of a plug in. Therefore there is no banking function.
And now I coming back to point 1) : please add 8 knobs to faderport, implement a banking function and a possibility to set all 8 faders and all 8 knobs (or 16 - because faderport 16 is also not the real solution - because for some plugins you really have more than 16 parameters to controller AND it is a big haptic difference to control some parameters with knobs or faders ) to control plugins , then I agree with you!
S1 4 Professional :+1
Audiobox VSL44 :( :cry:
Novation Impulse :)
iCON iControl Pro
by Lokeyfly on Sat Feb 01, 2020 6:47 am
The post was made quite a while ago, but with respect to "touch select" and if it worked in Studio One (I can't speak on the X-Touch, but I can on if Studio One shook hands with this).
Jemusic wroteJust out of interest even Faderport 8 which has a much deeper level of integration with Studio One won't do this. Touching a fader is not enough to select a track. Personally I am not sure I would want this anyway. On FP8 you have to bring the track of interest into view and then press the Select button for that track in order to select it.
On my Novation SL MKII, touch select works in that it indicates the track you will adjust that fader. I just checked, and it still works this way. What occurs is the fader highlights to show feedback of the selected fader is in fact that channel before committing to any fader movement. That's awsome.
I agree with Jemusic that I wouldn't want the actual channel to be selected (the whole channel highlighted).
Like the Novation SL MKII, the fader highlight indication is also shown with the FP8, or other touch sensitive Faderport. Channels selection should require pressing the respective channel button, or scrolling as can be done with the Faderport 8/16.
With respect to klausegon, sure, there are those differences, and a few more like FP8's rather week universal cursor control. Compared with Novation's simpler autodial mouse over, for instant use of dialing over virtually any parameter.
You can't fault the FP,'s one pan knob. You knew that buying it, and looking at the cost cutting to power ratio, Presonus did a great job here.
You also knew there was a main master volume knob. With 8 faders, it's not likely any fader could be reassigned to be a master fader.
On the third item, there are 8 fader, and 8 button iassignments, but true, you can't store them in the FP8 itself. Still, encoder banks can vary, independently, per channel, so you could have for example 20 different Pro EQ's each with 8 fader assignments, and 8 button assignments across those 20 channels independent of one another. You can save plugin setups within the devices when you map them though.
Yeah, too bad there are only the 8 fader + 8 buttons per with no savings of sets, where on the other hand, a Mackie, Behringer, or a. number of other HUI controllers can have multiple encoder storage. That is documented and was not some hidden secret, as I recall. You'll need that other multi bank controller.
I still recommend all of the FP's to each users need, so I can't slam the product at all.
For visability, you might want to enter your points about the FP8 in a new post (or the Faderport post). I get it though. The FP8 has its strong and weak points, but it's price point is really an advantage. Too bad there isnt some FP8+. ;)
Anyway, I'm sure like most of us, you're getting some great use out of it.
S1 Pro 4.6.x, Laptop: VAIO i7, 8 core, Win 7 64x. Audio Interface: Audiobox 22 VSL, Audiophile 192 Controllers: Arturia Keylab 49 MkII, Novation SL25 MKII, Faderport 8, Roland JV-90, Roland GR-50, Roland Octapad, Akai MPD-18. MIDI Patchbay: MOTU 8x8, Monitoring: Mackie HR824, Yamaha HS-7, Mixer: Yamaha Promix 01, Rane HC-6.
Latest albums on iTunes
LP's "Amber & Blue", and "Reasonable Approach" available on all major distribution music services.
Simply search "James Conrad Tucker".
All songs copyright. Be safe.
by lixisoft on Wed Feb 05, 2020 1:55 pm
Users with a controller that uses the Mackie MCU protocol should check this out.....
https://modernidiots.com/
______________________________________________________________
Mac Mini i7, 6 Cores, 16GB, 10.14.6, UA Apollo 8 Quad, 3 Sat Quads, FaderPort V2, Atom, Console 1, Studio One Pro V4.X.
PC i7 Quad, Win7/64, RME FF800, UA PCI Cards:1 Duo, 1 Solo.
by Lokeyfly on Thu Feb 06, 2020 4:08 am
lixisoft wroteUsers with a controller that uses the Mackie MCU protocol should check this out.....
Looks like a real good resource for X-Touch and MCU users.
I came whisker close to buying the Icon Qcon Pro some years back. Only, the FP8 had just entered the Frey. Glad I got it. I still like those other controllers too, and the X-Touch is also a bargain.
Love the close integration of the FP8 with Studio One.
I still drool over the SSL Nautilus II though. Only the budget has other priorities ;)
by patm300e on Fri Feb 07, 2020 7:33 am
Sorry, I guess I never posted this even though it was completed a couple years ago...Someone resurrected this thread so thanks for that!
Studio One - Xtouch.pdf
PDF File. I guess I never posted this. Hope this helps.
(1.52 MiB) Downloaded 74 times
by arjansmittenaar on Sat Apr 25, 2020 6:12 am
patm300e wroteSorry, I guess I never posted this even though it was completed a couple years ago...Someone resurrected this thread so thanks for that!
Top notch, thank you for all the effort... :thumbup:
by patm300e on Wed May 06, 2020 12:30 pm
Thanks!
by Jemusic on Wed May 06, 2020 4:24 pm
klausegon wroteI compared both and I'm very disappointed about Faderport.
You don't need a pan pot on every channel at all. The single pan pot works great. It pans any channel you select. Keeps the front panel uncluttered.
Master volume is simply accessed by pressing Master and the large rotary encoder takes over master level easily.
All parameters in plugins are now controllable over several pages.
by klausegon on Fri Oct 09, 2020 7:48 am
What I think what I need is my choice. The fact, Presonus opinion to tell users what they have to wants or not, will finally seen in success of a product.
If Presonus is happy with it - congratulations.
However, I see many devices are being squandered on EBay, so it seems, some users have after some expirience with this device the opinion, that there is not really a beneficial in the workflow.
One is the hardware, the other is the software integration.
The guys in Hamburg really made an effort!
We just have to recognize, that it is not trival to integrate the old MCU protocol better into StudioOne.
The desire on the part of the user is certainly there. This shows me the efforts of some users to improve the Mackie MCU template. Due to the software development for Faderport 8/16 - if you analyze the templates for the Faderport and MCU from the beginning, the similarity is more than obvious - I have the assumption that Presonus will not invest a lot of energy here.
Novation Impulse :)
iCON iControl Pro
by jesseharradine on Thu Oct 22, 2020 12:28 pm
Thanks!
Hey Pat , did you ever figure out if touch select works in Studio one? I was using a diff controller for a bit, the icon G2 and touch select worked out of the box on that one. Just setup an x-touch plus extenders and can't get it working yet...
34 postsPage 2 of 2
1, 2
Users browsing this forum: Tacman7 and 70 guests
