PreAl wrotedaniellesaux wroteI heard back from Waves support and they sent me a link for a V9-V10 Organizer for PC. According to tech support "the Organizer will go over the Waves licenses activated on your system and verify that only the correct version of your plugins is installed." He said this should fix the issue. Sure, here is the link. Please note that I haven't tried this yet so please proceed cautiously! ![]() https://emea01.safelinks.protection.out ... reserved=0
Peace!
Dan PreSonus Studio One Professional 5.1.1 Windows 10 64 bit Skylake Desktop PC with Intel i7 6700k processor @ 4.20 GHz / 16G RAM Intel HD Graphics 530 Toshiba HDWD110 1TB System Drive, Toshiba HDWD110 1TB Audio File Drive, Samsung SSD 850 EVO 500GB Samples Drive, Seagate BUP Slim BK 2TB USB Backup Drive PreSonus 1824C Audio Interface PreSonus Faderport 2018 PreSonus Studio Channel Check out my website http://www.daniel-lesaux.com |
There is a larger issue here that has *nothing* to do with v9 plugs not under WUP.
Last month, I purchased and installed Vocal Rider, so v9 installed. All good in Studio One 4 and eligible for v10 upgrade. Last night, I purchased Scheps Omni Channel. When I went to install, Waves Central upgraded itself. v10 of Omni Channel installed, then offered to upgrade licenses to v10 (went fine, according to Waves Central), then I chose option to delete old v9 stuff. Then launched S1. It still only saw Vocal Rider. I cleared blacklist and rescanned. Still just Vocal Rider. I moved licenses to cloud and back to my PC. Still just Vocal Rider. In Central, I uninstalled all plugs (v9 and v10). Relaunched S1. All Waves plugs gone (*finally*, something as expected!). I re-installed *just* Omni Channel and relaunched S1. Guess what? VOCAL RIDER SHOWED UP!!! What the heck? So, something is seriously confused and caching old plugs! So, I moved licenses to cloud, uninstalled Central, deleted C:\ProgramData\Waves Audio folder (which oddly still had a v10 directory), downloaded the v9 archive from Waves, installed the legacy Waves Central from that archive, then installed *just* Omni Channel and relaunched S1. Guess what? VOCAL RIDER SHOWED UP AGAIN!!! Onward... Uninstalled v9 Waves Central. Scanned Registry. No trace of "vocal rider" or "rider." Scanned C: drive. Deleted all folders under Program Files and Program File (x86) that had the word "Waves." Also deleted C:\Users\[my username]\AppData\Roaming\WavesAudio folder. Rebooted. Re-installed Waves Central v10. Installed just Scheps Omni Channel. Launched S1. Any frickin' guesses what showed up there under Waves plugs? VOCAL RIDER!!! Also, files and folders referencing "Vocal Rider.bundle" showed up again under AppData!!! I'm about to lose my mind!!! This is CRAP!!! ![]() P.S. That V9-10 Organizer app runs some type of script and did *nothing* to help me. |
mBrane wrote. I cleared blacklist and rescanned. Delete the all the VSt folder paths, rescan, restart, then put them back in... ditto. Cheers.
Intel i9 9900K, 32GB RAM, EVGA Geforce 1070 (Nvidia drivers). Dell Inspiron 7591 (2 in 1) 16Gb. |
PreAl wrotemBrane wrote. I cleared blacklist and rescanned. Oh. My. THAT FIXED IT!!!!!!! HAPPY DANCE!!!!!! ![]() What a bunch of crap! I deleted all VST paths and didn't even add them back and S1 told me that it would update on restart. Wow. Why the heck would I have to do that?! Evidently a caching issue with S1 that they *desperately* need to expose in the GUI! You would *think* that checking the box to scan on startup and clearing blacklist would be the extent of it! Anyway, PreAl, you made my day!!! Thank you, thank you!!! |
^^ Has been logged. Cheers.
robertanderson14 wroteI tried the uninstall route and other things too, but didn't work. Thank you! I decided to link it in the directory C:\Program Files\Steinburg\VSTplugins\ and it worked! That is after re-installing and re-activating via Waves Central failed. |
Future DLL hell right there. Mark my words.
PreAl wrote^ Thanks PreAI. Just tried again. For some reason, Studio One Pro 4 does not see WaveShell1-VST 10.0_x64.dll in it's default directory, no matter how many times I reset the paths inside SO and re-scan, however if I link (it's still in its original path) it, or even install V10 plugins in a different location, SO sees the V10 DLL. I will keep it as is for now as it works, however thank you for the heads up as I will revert back to the original path as soon as there is an update to Waves Central or SO to avoid potential future problems. |
zeljkobozin wrotePreAl wrote^ Same issue here! I had to revert to V9 for SO4 to see my Waves plugins. It just doesn't see the Waveshell file.
Peace!
Again, fix that worked for me is above (ie. deleting VST path from Studio One, which triggered rescan/update of Waves shell). If that doesn't work for you, here are instructions for a complete re-install that Waves Tech Support provided:
If you have IR convolution reverb impulse files, please back up the following folders: C:\Program Files (x86)\Waves\Data\IR1Impulses C:\Program Files (x86)\Waves\Data\IR1Impulses V2 C:\Program Files (x86)\Waves\Data\Acoustics.net Impulses (if exists) First, uninstall: Launch Central. Go to Install > Uninstall, check mark both boxes and click Uninstall. Go to Control Panel > Programs and Features and uninstall Central. Go to C:\Program Files (x86) and delete the Waves folder. Press [Win key]+R, type %AppData% and hit Enter. In the Roaming folder that shows, drag the Waves Audio folder to your desktop. Press [Win key]+R, type %LocalAppData% and hit Enter. In the window that shows, delete the Waves Audio folder. Press [Win key]+R, type %ProgramData% and hit Enter. In the window that shows, delete the Waves Audio folder. Delete any WaveShell files you find in the following locations (if exist): C:\Program Files\VSTPlugins C:\Program Files\Common Files\Avid\Audio\Plug-ins C:\Program Files\Common Files\VST3 C:\Program Files (x86)\VSTPlugins C:\Program Files (x86)\Common Files\ DigiDesign\DAE\Plug-Ins C:\Program Files (x86)\Common Files\VST3 C:\Program Files (x86)\Common Files\WPAPI Now to re-install: Download and install Central. Run Central and log in. Go to Install Products. On the left column, select Online. On the middle column, click on My Products and select the products you wish to install. Click Install on the bottom right. |
No issues here with upgrading eligible plugins to v10 and keeping all the others at v9 that were not under WUP and therefore not eligible for upgrade, everything is in default locations and all work fine in Studio One 4. The whole process was pretty straight forward and easy, hard for me to imagine all the difficulties I have read about.
For me it was just a matter of going to the Waves site, selecting my products, clicking on the upgrade link next to one of my eligible plugins which open up another page which had all my eligible plugins listed, select all and hit upgrade, received a message saying licenses were applied, installed the latest version of Waves Central, select the upgrade eligible plugins, it asked whether or not I wanted to upgrade everything or just the selected plugins, I chose just the selected plugins, hit the button and all was done. Everything works as normal and I have my upgraded v10 plugs working happily alongside the rest of the v9 plugins. Easy as. |
jih64 wroteNo issues here with upgrading eligible plugins to v10 and keeping all the others at v9 that were not under WUP and therefore not eligible for upgrade, everything is in default locations and all work fine in Studio One 4. The whole process was pretty straight forward and easy, hard for me to imagine all the difficulties I have read about. This was my experience as well, the exception was that my new purchase wouldn’t appear in my S4 inventory despite my being notified of installation success. In fact the only way to bring it up was as an insert in another plugin like Blue Cat Patchbay. It eventually fixed. I have no idea what the issue was. |
daniellesaux wrotePreAl wrotedaniellesaux wroteI heard back from Waves support and they sent me a link for a V9-V10 Organizer for PC. According to tech support "the Organizer will go over the Waves licenses activated on your system and verify that only the correct version of your plugins is installed." He said this should fix the issue. Tech support sent me the anyway link and I ran the utility. After this two plugins which were V9 went up to V10 as should be expected. So that resolved my secondary issue. So all I need now is how to get this multi rack freebie installed, I have licenses installed locally but it won't install anywhere. I'll wait for support.
Ran the utility and still no luck recognizing the V10 versions. This is crazy! I contacted tech support again,
Peace!
Hey guys, I went through tech support and this fixed my problem. Hope it helps.
Go to %AppData%. In Roaming, go to Presonus > Studio One 4 and drag the “x64” folder to the desktop. Launch Studio One 4 and check if the issue persists. If it works, just delete the x64 folder on your desktop as it creates a new one at startup. |
In case anyone stumbles here and is afraid to upgrade and ALL of your plugins are current at version 10, just go the Waves website, upgrade all of your plugins to V10 through your account there and then run Waves Central. Install the new version when prompted and do the V10 install from there.
Everything works without a hitch. |
daniellesaux wroteRan the utility and still no luck recognizing the V10 versions. This is crazy! I contacted tech support again, I did a totally clean install of Waves central and my v10 plugins. SO4 did not see them. I did everything suggested in this thread. No v10 seen by SOv4, but seen by Cakewalk and Cubase, so they had been correctly installed. Finally, added WaveShell1-VST 10.0_x64.dll into the C:\Program Files\CommonFiles\VST3 folder. Restarted and rescanned. AND Waves plugins V10 finally show up in the plugin FX list!! |
brandonrobertson2 wroteHey guys, I went through tech support and this fixed my problem. Hope it helps. Also had tech support on the phone today and this is exactly what he did and it finally fixed my problem. It forces a complete rescan of all plugins.
Peace!
daniellesaux wrotebrandonrobertson2 wroteHey guys, I went through tech support and this fixed my problem. Hope it helps. Imho those who were copying DLLs (do not recommend) should undo that action and do this (see if it works for them). The other way to force a scan was to remove the plugin folder paths and put them back in, recreating the folder however (as quoted) sounds like a better idea (or do both).
Users browsing this forum: gregghart, pierregauthier and 39 guests
